chevydriverz28
10-18-2009, 01:14 AM
I'm buying a 95 LT1 Z28 this weekend and need to drive it back cause its 2 and a half hours away. The problem is it wont start because of fuel delivery problems. I need to know every possible problem I could check before having to "nails on a chalk board" change the fuel pump. What are all the things you would check first. I haven't seen the car yet but the seller said it ran fine until a few weeks ago when the fuel pump sound stopped humming when the key was turned forward. He said he checked the fuses and relays and all seemed fine. I will probably go there with tools in hand prepared to replace the pump but I need to know EVERYTHING to double check before i take on that bear.
Thanks in advance for any help you can lend.
Brandon
Brandon
