Small Block & Big Block Chevy Specific - crankcase venting
View Full Version : crankcase venting
tunedports10
10-18-2009, 12:22 PM
Currently have a lot of crankcase pressure pushing oil out seals and what not. My current system is just a line from each valve cover going to a dual inlet catch can from allstar(http://www.amsperformance.com/cart/Allstar-Universal-Catch-Can-Amsperformance.com.html). Just wanted to see what people thought about doing something like the picture below. This is on a Turbocharged 383
http://i33.photobucket.com/albums/d52/Tunedports10/possibleevacsystem.jpg
mrdragster1970
10-18-2009, 01:58 PM
I don't like dumping that crap back into any engine. Especially not a N2O or boosted one.
I don't want any contamination in my charge. I'm not a turbo expert,
but it might be worth a vacuum pump. If it's too much, at least try an evac kit.
Check jegs or summit and you can get some ideas & pricing.
tunedports10
10-18-2009, 01:59 PM
Thats why I would using a breather/seperator tank to seperate the air from the oil so the oil wouldn't go back into the engine. My thinking could be incorrect though.
tunedports10
10-18-2009, 03:10 PM
I also am thinking about using a lt1 electric smog pump hooking the inlet of the pump to the valve cover
KOOSWS6
10-22-2009, 09:47 PM
I am having some of the same issues with too much crankcase pressure. Does venting the valve covers help with crankcase pressure? How do the gases get up there, through oil passages? Is there a better way to vent the block?
LS6427
10-23-2009, 12:06 AM
Yes, if you put a breather/filter on the valve cover ports or an oil fill cap breather/filter you will eliminate any crankcase pressure from building up anymore. The crankcase gases flow right up into the valve covers.
But you should still pull crankcase gases/moisture out somehow. External vaccum pump venting to the atmosphere....or using a catch can and the normal vaccum port on the intake.
