fbodyfreek
10-18-2009, 05:19 PM
i might be a little paranoid, but underneath where the battery sits in the engine bay my car has developed rust on the passenger side directly behind the radiator. if i had to guess the total area covered is roughly only 4"x6". it's not big, but just enough to make me wonder. i believe the cause was battery acid. i don't know anything about body work, but should it be replaced or is it not big enough to critically endanger the frame? and if i were to replace it what specifically would i be replacing? there's a little spot on the hatch too... i guess the best question would be, "When should I be concerned with the integrity of the frame, so far as rust?" thank you.
