Generation IV External Engine - LS6 Intake manifold on LS2
Andrew R
10-18-2009, 06:49 PM
I have a 2005 LS2 engine from a GTO and I'm ditching the DBW and going with a LS6 intake manifold and LS1 ECU from a 04 GTO I would also like to switch to the LS6 valley cover while I'm at it
So far I have the LS6 intake/TB/injecters/all sensors with aeromotive fuel rails, ECM, harness.
Is there anything else that I need? I keep reading about coolant passages and am wondering if I'm missing anything.
Thanks in advance.
Phoenix 5.7
10-18-2009, 08:51 PM
coolant passages are for LS1->LS6. u already have that. and u should already have a ls2 valley cover which is at least as good as the LS2. ls6 valley will have knock sensor holes u won't use.
SweetS10V8
10-18-2009, 09:37 PM
Changing the wiirng harness also? The LS6 throttle body and PCM will take a TPS and IAC sensors that a DBW car doesnt have.
Andrew R
10-20-2009, 07:16 PM
Thanks guys!
Yeah I'm also changing the harness so I need to extend it for knock sensors and I also understand the cam sensor wires need to be reversed. The LS2 I have is 24x :angel:
anheuserbusch08
10-20-2009, 07:24 PM
any ls2 parts gonna be up for sale?
Andrew R
10-20-2009, 08:51 PM
Yes sir!
I have a brand new LS2 PCM, LS2 intake manifold and some other goodies. I need to get the engine from the donor car and then I'll start posting stuff up.
JDMC5
10-20-2009, 11:29 PM
might I ask why you are doing this?
Andrew R
10-21-2009, 06:23 AM
Several reasons... This is a swap, it's going in a RX-7 I bought the engine as a long block (with some extras) and it did not come with the DBW TB or the pedal assembly -found a great deal on the LS6 intake manifold completely loaded off of a GM crate engine NEW 0 miles... Needed to buy the PCM and harness anyway - so why not go cable TB?
RapidRick
10-21-2009, 10:34 AM
Sounds like a great project Andrew!
Please post some pics as they become available and time allows you.
Somewhat like a start to finish idea.
Best of Luck on your ride! :burn: :drive:
Andrew R
10-21-2009, 06:21 PM
Thanks! things have started moving on the build!
Just pulled the rotary and started prepping the chassis.
here is my build thread:
http://www.ls1tech.com/forums/conversions-hybrids/1129697-my-ls2-fc-build-thread.html
JDMC5
10-22-2009, 12:19 AM
Sweet man good luck with that. That car should rip! You should run a 90mm TB with that, should be worth a couple hp over the LS2 intake too.
amkoolaid
10-22-2009, 01:35 PM
I'm building a 6.0L ls2 for a 99 WS6 and my ls6 off of my 5.7L ls1 intake doesnt fit. Seem to be to narrow??? and ideals???
Andrew R
10-22-2009, 02:02 PM
Should go right on....
I'll be test fitting mine soon.
rock your world
11-11-2009, 12:32 AM
do you still have the ls2 intake?????
