General LSX Automobile Discussion - Is there a reason GM went with single exhaust?
USArmyZ28
10-18-2009, 08:37 PM
I was just wondering, keep cost down or is there something else I am missing?
DownSouthWS6
10-18-2009, 08:45 PM
i reckon youre refering to the y-pipe? and im pretty sure its because the suspension gets in the way of the of dual pipes. which is why my bullets are dumped before the axle and my x-pipe scrapes over speed bumps.
69camaross
10-18-2009, 09:45 PM
It all started in 75 with the cat finding it's way onto the f-body. From 75 until 89 they only ran one cat so all exhaust gasses had to go through one pipe. Now consider the platform under your Z28 was basically designed in the late 70s and that will clarify why.
Striker
10-19-2009, 09:13 AM
I always wanted to know this as well.
*Briefly off topic since the above member mentioned chassis** What frame/chassis is used in the late 4th gen's? Is it a carry over from something else or an older F-Body? For example like the stangs all the way up to 04 used the old out dated fox body chassis.
deelong4002
10-19-2009, 09:20 AM
The fourth gen platform is pretty similar to the 3rd gen platform. My brother has an 89 Camaro and its very similary underneath. However his engine doesnt sit under the cowl :bang:
Striker
10-19-2009, 10:10 AM
Despite of everyone complaining about this, including a lot of mechanics I kind of like it and Im sure they did this for a reason. Look how much forward the engines in stangs sit compared to our cars.
LS1W66
10-19-2009, 10:36 AM
To get that slick windshield angle the designers had to extend the cowl over the engine.
And the Platform is basically refered to as the 4th Gen F-body (because all the other Gens are their own aswell). The only real thing shared between the 3rd and 4th gens is the rear suspension design. And the Single exhaust is due more to packaging constraints and peice costs.
aerojt
10-19-2009, 02:35 PM
Why did the 98 SS's and WS6's get a single tip out the back and not duals? I was wondering that, since I had it for a little bit...
69camaross
10-19-2009, 02:45 PM
The 4th generation floor pan with the exception for the firewall forward is a barely modified 3rd gen chassis. That's why single exhaust was retained due to re-engineering costs. It was referred to as the 4th generation because of the new outward appearance vs. the boxy 3rd gen.
The 98 WS6 SS "one on the left" was supposed to be the new version of the famous "two on the left" SLP exhaust but it didn't catch on and was dropped in favor of the Dual Dual SLP setup.
eseibel67
10-19-2009, 02:49 PM
The floorpan is also common between 3rd and 4th gen. The passenger floor "hump" on a 4th gen is a remnant of the 3rd gen catalytic convertor cove.
The engine in a 4th gen isn't "back", it's just that the windshield's leading edge is so far forward. Like an Intrepid lol.
Striker
10-19-2009, 03:00 PM
I understand what you're saying. But if you look where the very front of the engine is in co-ordinance where the strut tower's are it is in there pretty good. As I said before, compared to a stang its positioned much nicer.
01ssreda4
10-19-2009, 11:26 PM
I agree.....:D
1995blacktattop
10-19-2009, 11:36 PM
a stock 4th gen cat sits in that hump as well. here is my stock cat under my 95.
http://i237.photobucket.com/albums/ff279/pdennis93/generic%20photos/100_0608.jpg
01350ss
10-20-2009, 01:11 PM
that is the lt1, the ls1 has the cats hugging the engine. the floor hump is not needed in 98 and newer.
LS1W66
10-20-2009, 01:21 PM
Incorrect
2000 -up LS1 F-bodies have the Cast iron manifolds with the newer cats
`98-99 cars still have one of the 2 cats under the floor hump.
1995blacktattop
10-20-2009, 01:24 PM
that may be the case but since they didn't change the car from the mirrors back there is a reason why an LS1 car would still have the hump since it was necessary for the LT1 (and apparently the early LS1)
USArmyZ28
10-20-2009, 03:20 PM
I read somewhere the engines are under our cowl and pretty far back is to put more weight to the center of gravity. I am not 100% sure if that is the case but it would make sense.
The reason I asked the original question is because I have true dual exhaust that goes over my axle (Bassani) and I really love the way it sounds. But I dont think it is loud enough, but it could just be me since I was running two open cut outs with a big cam lol.
dutinsss
10-20-2009, 03:37 PM
your right, one of the reasons the engine is so far back is to position the weight more to the center of the car. not to say that's the only reason, though.
eseibel67
10-20-2009, 04:51 PM
Yes, there is a reason - $$$.
It would have cost a ton of dough to re-tool the floor to be flat. It's much cheaper to re-use the old floor that still has an uneccessary hump.
Scira
10-20-2009, 07:59 PM
x2 that's what I've always heard. GM was too cheap to delete the hump, so they just kept it.
Detoxx03
10-21-2009, 01:13 AM
I would think due to clearance issues
Marc 85Z28
10-21-2009, 07:17 PM
Really!? Look under a V6 car...
