Generation IV External Engine - 1 3/4" headers vs 1 7/8" headers
yuimyt
10-18-2009, 11:43 PM
What exactly are they different?
If I won't get any forced induction, which is better??
jdiddyws6
10-19-2009, 12:15 AM
One has one size primaries, and the other is larger. Might as well get 1 and 7/8's, seems like they are becoming more widely available.
massconfusion
10-19-2009, 12:42 AM
17/8 will give you a little more topend while and you will also loose a little more lowend torque then you would with 1 3/4. It wont be as noticable as 1 5/8 compared to 1 7/8. personally i recommend 1 7/8 because I race on the street and track. You race in the topend not the lowend. in the end it matters what your needs/wants are out of your car, but between the two their is not a big difference espcially if you are mostly stock
the_merv
10-19-2009, 12:44 AM
1 7/8" flow about 13% more than a 1 3/4".
Zmg00camaross
10-19-2009, 01:10 AM
tsp 1 7/8 here for me and fit great with poly mounts installed
LS1LT1
10-19-2009, 02:18 AM
but between the two their is not a big difference espcially if you are mostly stockI agree. :nod:
yuimyt
10-19-2009, 12:29 PM
Thanks guys.
What about sound difference? one is deeper and louder????
JDMC5
10-20-2009, 11:32 PM
Thanks guys.
probably not. Go with the 1 7/8"
jmilz28
10-24-2009, 10:22 PM
People who say you "lose low end" are misinformed and are buying into a myth. Go for the 1 7/8 and get a dyno tune and prepare to be happy.
2002_z28_m6
10-25-2009, 08:11 AM
I would just go 1 7/8 and be done that is what I did. No lack of low end here.
JFM-jr
10-25-2009, 09:34 AM
I agree, TSP has seen gains on a stock LS1 with 1 7/8 over 1 3/4 on the engine dyno.
JayplaySS2
10-25-2009, 11:32 AM
1 7/8's all the way, they will have less wiggle room around things but you will never have to get another set. You can grow into them and sacrifice nothing while lighlty modded. They make more power with N20 but they are nearly indentical when FI'd (from CF posts). If you ever go larger cubes though, you will have them already.
Search Corvette Forums for more info, those guys are nuts about having these threads.
WADDISME
10-27-2009, 03:14 PM
Here is a back to back comparison:
http://forums.corvetteforum.com/c5-tech/2362814-step-inside-to-gain-knowledge-detailed-a-b-comparisons-with-results.html
No loss of torque.
LSX Truck
10-28-2009, 01:51 AM
1 7/8, u never know when you'll be running into any power adders
MeentSS02
10-30-2009, 03:38 PM
Agreed...as for a sound difference, they are almost identical (I went from Kooks 1-3/4" to Kooks 1-7/8"), but the 1-7/8" headers sound a bit more pissed.
If I had to do it over again (and not spend money for headers twice), I would have went with 1-7/8" headers from the beginning.
Formulals187
10-30-2009, 06:12 PM
I switched this summer from flowtech 1 3/4 to TSP 1 7/8, good decision, better sound much better power especially up top
bigwillys58
10-30-2009, 10:11 PM
i went 1 7/8 kooks with cats and i couldnt be happier
