Cadillac CTS-V 2004-2009 - No start
TomJoeC88
10-20-2009, 03:21 PM
I got in my car on sat after dinner and turned the key only to hear one quiet click. I actually had to double check I had my foot on te clutch lol. I did. The battery is only months old an like I said only oneclick not multiples. Jump start with cables from a friends car did not work so we actaully push started it. I know how crazy a sight to see a caddy getting started with a clutch pop lol. Anyway I have it sitting in the garage now (too afraid to get stranded til I look at it) it has started a half dozen tomes on it's own and the done the same thing. This time I jumped it with a battery charger. Now I'm confused. when I actually get more time to look at it where should I start? Is there a relay to look at or test the starter see if the solenoid is bad? This is odd
jerrad
10-20-2009, 03:44 PM
Have you disconnected the cables to see if there is any crap built up between the terminal and the cable? That's always my first step.
demang
10-20-2009, 07:22 PM
check the wire to the starter. mine did the same thing. my wire was burnt. good thing i was at the dealer.
shake your cable running to the starter. Crappy connection. You will need to remove the nut from the stud and add a thick washer to stand the lug off of the starter a bit. Happened to me about 5 times before i found the problem
adanieljohnson1
10-22-2009, 02:47 PM
Hope this helps...
http://www.ls1tech.com/forums/cadillac-cts-v-2004-2009/1182741-car-wouldnt-start-today-2nd-time-happened.html
TomJoeC88
10-22-2009, 06:03 PM
So what was the verdict with yours?
ELES6CTS
10-23-2009, 11:44 AM
Did you ever figure out the problem?
TomJoeC88
10-29-2009, 09:40 AM
cleaned up the positive terminal on the starter and its starting for now, but was that a plug connector on the ignition key wire??? cuz mine looked a little messed up (possibly the problem huh??) man thats goofy
TexVette
10-29-2009, 10:29 AM
Check the terminals to make sure they're tight.
Check the battery main ground.
Make sure you didn't burn any starter wires on a header.
Had a similar problem and it was the battery ground terminal. When mine did this, the clock would reset. Good luck.
