Fueling & Injection - need help, tvs2300 upgrading fuel injectors?
tom's2005gto
10-22-2009, 07:43 AM
Currently have a forged 402 with a maggie 122 in my 2005 GTO. Making 625rwhp and 630 torque. I have purchased a new TVS2300 with plans of 800rwhp.
The 2300 has stubby 63lb injectors that need to be replaced with 79lb. The 63's are 2" tip to tip. The 79's are about 3 1/16". The problem is the fuel rail on the drivers side runs under the vacum actuator, so not enough room to just raise the rail up. Not a lot of room between the fuel rail and the valve cover.
Suggestions?
Possibly run the 1 & 3 injectors off of some sort of snap on fuel block with a line to them individually?
FICINJECTORS
10-23-2009, 07:30 AM
Suggestions?
Possibly run the 1 & 3 injectors off of some sort of snap on fuel block with a line to them individually?We have the mini Bosch ev14 in sizes from 42 to 90lbs These are a direct replacement with the right electrical plug also, no adapters required
tom's2005gto
10-23-2009, 10:27 AM
^^^^ I talked to Jon yesterday, great knowledgeable guy. Order placed!
Thanks, Tom
LSX Truck
10-28-2009, 02:18 AM
lemme know if your going to get rid of the 63lbers.. what make are they?
tom's2005gto
10-28-2009, 02:20 PM
sending pm
