Fueling & Injection - 2 questions...which injectors ls3's or 42lb'ers and how?
Nimitz87
10-22-2009, 07:47 PM
Ok swapping in an lq4 truck motor and using L92 heads, LS3 intake etc.
the intake came with new LS3 injectors which are rated AFAIK 36lb @ 3bar.
I have had a set of 42lb green tops (@ 3bar) in the ls1.
is the leap in technology from the ls3 injectors to the 42lb injectors big?
is the 6.5lb/hr difference for the 42lb'ers that big of a deal?
now I know with ls1 style injector I would need the different o-rings and spacers.
with the ls3 injectors all I would need is the plug adapter correct? If so what sponsor makes one?
Chad
FICINJECTORS
10-24-2009, 07:22 AM
Chadthat ls3 injector is light years above the 25yr old green top. We have the wire adapters for 39 a set and can also resize that injector up to 60 lbs. So you never have to buy new injectors..
69LT1Bird
10-24-2009, 08:09 AM
The LS3 injector is 39 @ 4 bar (GM pressure). You will be fine with those. Easy to tune and less hassle.
Nimitz87
10-24-2009, 02:02 PM
I couldn't find them on your site...could you pm or post the direct link please?:emb:
if that's the case then I'll definitely go with the LS3 injectors...
Chad
FICINJECTORS
10-24-2009, 04:28 PM
Chadhere ya go
http://fuelinjectorconnection.com/shop/index.php?_a=viewProd&productId=23
LilJayV10
10-29-2009, 11:27 PM
I was looking at injectors around 36-42. I am doing a H/C/I swap soon and I don't know what injectors to get.
What is the 3 bar, 4 bar you are mentioning? Thanks for any help.
LilJayV10
10-29-2009, 11:29 PM
I just saw these are for the LS3 intake. I have a LS6.
FICINJECTORS
10-30-2009, 08:26 AM
I just saw these are for the LS3 intake. I have a LS6.a ls6 uses a full length injector 60mm oring to o ring. The ls3 injector is 40mm. you will not be able to fit the ls3 in the ls6. If you can call me I will explain all your options. 770 888 1662
jon
jegten
11-06-2009, 01:14 AM
should i call you too? :D
i, too, have the ls6 intake and am wanting to change injectors. currently, i have the 42 lucas (delphi, or whatever they are called).
i would like to get some 42#s or close, so long as they fit my intake. i am up for suggestions.
thanks!
FICINJECTORS
11-06-2009, 08:16 AM
thanks!pm sent
jegten
11-06-2009, 06:21 PM
thanks Jon!!!!:hail:
