Dyno & Bench Racing Forum - H/C power guesses?
firechicken76
10-23-2009, 01:00 AM
Ok, just wondering if anyone could give me a good estimate on how much power i can expect to make on my combo im putting together.
currently has...
2002 LS1
1 3/4 LT's
ORY
SLP loudmouth exhaust
25% UD pulley
LS6 intake
Ported Throttle body
NGK iradium plugs
msd wires
No a/c
no air system
K&N filter on a custom intake tube
ls7 clutch
40k on motor
ford 9" rear with 4.11 gears
aluminum driveshaft
car is a 1988 trans am GTA
what im adding to it now...
Ported by BES 853 heads (no flow numbers)
MTI X1 cam 232/228 595/572@112
stock ratio full roller rockers
918 springs
hardened pushrods
ls2 timing chain
TUNE
speedshifterNC
10-23-2009, 11:56 PM
430 is my guess
firechicken76
10-24-2009, 01:17 PM
430 is my guess
that would be sweeet, then id do the fast 90
the jester 812
11-03-2009, 12:12 AM
i dont want to be the party pooper but i think 430 is a bit high. my guess would be 399. but im a glass half empty kind of guy. but the way i look at it is you have a engine making 315whp or so stock, so full exhaust and a cam would have to add over 100whp. my guess is it will net you about 70. but ehh thats just my 2 cents.
firechicken76
11-03-2009, 12:58 AM
I have headers, no cats, underdrive pulley, ported throttle body, ls6 intake, loudmouth exhaust, Custom intake.
and the cam will be ported heads, cam, roller rockers, springs, ls7 lifters, pushrods gaskets etc.
then why are all the other bolt on ls1's with an mti x1 cam making about 400 to the wheels?
http://www.ls1tech.com/forums/dynamometer-results-comparisons/954665-mti-x1-cam-only-dyno.html
http://www.ls1tech.com/forums/dynamometer-results-comparisons/834462-mti-x1-dyno-results.html
http://www.ls1tech.com/forums/dynamometer-results-comparisons/869873-mti-x1-a4-stock-heads-70-rwhp-gain.html
firechicken76
11-03-2009, 01:38 AM
I may be getting a magnacharger instead of doing this install. I found one for 1800
firechicken76
11-05-2009, 11:16 AM
how about this guys?
full bolt ons, radix magnacharger, 3.0 pulley 500rwhp?
