Generation IV Internal Engine - ls7 lifter question?
denali-08
10-23-2009, 05:35 AM
well I have a 2008 gmc single cab with a 6.2 engine, it have gone trought 6 stock lifters, will the ls7 solve my problem or should I buy another ones. btw I am shifting at 6800 rpm thanks
69LT1Bird
10-23-2009, 07:27 AM
You may want to give some more detail, something sounds very wrong to be eating up lifters like that.
Gordon0652
10-23-2009, 07:59 AM
Thinking the same...
denali-08
10-23-2009, 01:59 PM
well the first time that lifters broke was bacause the cam was not thighten as it should be so the cam moved while I was driving and 3 lifters broke, i replaced them with 5.3 engine lifters, so maybe 5.3 lifters are not good .
denali-08
10-23-2009, 08:32 PM
bump!!
DVS99TRANS
10-23-2009, 08:40 PM
Technically the LS7 lifters are now stock. They don't produce stock LS1 lifters anymore. I don't know if the 5.3 and LS1s had the same lifters although I assume they would. Throw the LS7 lifters at it and call it a day. It may be a good idea to get new pushrods while your at it. The LS7 lifter cup sits roughly .06 higher than stock.
cutlass_455
10-23-2009, 10:22 PM
Are the lifters turning in the trays?? Does that sound like something that lines up with your problem?? Maybe consider replacing them too.
muayyadf1
10-25-2009, 07:26 AM
You might have too much preload that eats your lifters. Check pushrod length
