evangto87
10-23-2009, 01:43 PM
first set of races is between a 2000 ss camaro with just a full exhaust (traps 113) and a c5 z06 ("stock"). Second set is between that same z06 and a well built heads cam camaro built in his garage. By the way.... the heads/cam car was down a cylinder. We didnt know until after the race.
http://www.youtube.com/watch?v=VCWz5GhB77I
ScreaminRedZ
10-23-2009, 04:47 PM
Good races.
You sure the H/C car didn't lose a cylinder after the races? He seemed to pull quite hard on the Z06.
evangto87
10-23-2009, 04:51 PM
Good races.
yea positive. The car put a push rod through the rocker arm and it stayed wedged in it. Wasnt opening the exhaust valve on cylinder 1. I asked him what that noise was before the race and he said it was an exhaust leak. But after the races when the cut out was open at idle, you could hear the misfire or i should say lack of big cam. He had yella terra rockers. Switch back to stock. If u listen to the third race where he gives the zo6 a couple cars and the jump. You can hear when it hits 5th gear, it sounds like it has nothing in it. His car pulls awesome through 5th gear.
