jdiddyws6
10-23-2009, 02:32 PM
Built 347 LS1 block
LG motor sport long tube header with X pipe
Callies rods
12:1 diamond piston 2 degree valve relief
450 precision injector
New crank
New fly wheel
Fast 90 intake/throttle body
Trick flow 215, 58cc heads ported
crower retainer
crower spring
ferrea valve
Comp. cam roller lifter
Comp. cam cr-mo push rod
Comp. cam cam shaft custom ground 242/244 624/622 111
3 degree advance
Harland and sharp roller rocker arms
RPM stage 5 tranny (new just install 2 week ago) w/spec stage three clutch
Coursa indy cat back
Stock z06 rear end with 342 gears
Nitrous express progressive system with bottle warmer/purge system
B & M ripper shifter
06 z06 rims
motor has 7800 miles on it when the car was at 55k now the car is 57k mile this car will run low 10 with the right tires i have a video of it running mid 10s spinning down the track
http://videos.streetfire.net/video/MMP-14-Mile-2008-Mustangs_193935.htm
skip to 4.10 and you see the run
asking price is 28k OBO clear title
here some pic
http://i89.photobucket.com/albums/k214/skyteggy/z0sick4.jpg
http://i89.photobucket.com/albums/k214/skyteggy/Z06HR11.jpg
http://i89.photobucket.com/albums/k214/skyteggy/Z06HR10.jpg
http://i89.photobucket.com/albums/k214/skyteggy/z0sick.jpg
http://i89.photobucket.com/albums/k214/skyteggy/interior.jpg
http://i89.photobucket.com/albums/k214/skyteggy/engine.jpg
http://i89.photobucket.com/albums/k214/skyteggy/bottle.jpg
Callies rods
New crank
New fly wheel
crower retainer
crower spring
ferrea valve
3 degree advance
06 z06 rims
here some pic
