svshawk03
10-23-2009, 03:39 PM
So i have had my car recently dynoed at 2 different performance shops cause the first dyno results came back to be a little odd so I wanted a second shop to make sure this the real numbers...Ok first I have a early model 98 z28 camaro 6 speed...All i have for performance mods are dynatech longtube headers with cats, slp loudmouth exhaust, spec stage 2 clutch with aluminum flywheel, tunning by hp tuners, slp lid and k&n filter. everything else is stock...and the only thing that was found different on my motor compared to the later models is mine comes from the factory with 28lb injectors...
The results from the first dyno were 305 hp and 430 ft. lbs. torque at the rear wheels
The results from the second dyno were 310 hp and 432 ft. lbs torque
what I want to know is why are the torque numbers so high? I mean im not complaining..:drive:
