Fueling & Injection - Need Info on AN fitting O' Rings.
View Full Version : Need Info on AN fitting O' Rings.
Dwn Cam
10-23-2009, 04:33 PM
I am putting my fuel system together and I need various O'Rings for all my male AN fittings. AN-6, AN-8, AN-10, AN-12. I need to know the ID and OD of each of the O' Rings so I can tell my supplier what I need. Are there any links that will give me the info I need?
Thanks,
DAS1998
10-23-2009, 05:10 PM
Most fittings with orings { ORB Fittings} Are machined Differently then non oring style just so you know.
I hate playing musical fittings.
Dwn Cam
10-23-2009, 07:31 PM
Yeah me too!
These are the fittings i have.
http://www.runroadrunner.com/id83.html
ak95ta
10-24-2009, 02:07 AM
Yeah me too!
Umm, those fittings don't require o rings. The sealing surface is the 37* flare. No sealant of any type is to be used either.
Dwn Cam
10-25-2009, 06:40 PM
That's originally what I thought, but the shop installing
the system was asking for them.
Mike52
10-30-2009, 11:55 PM
I'm thinking someone at the shop doesn't know what they're doing, the fittings in the link you provided don't use o-rings.
As ak95ta said, an AN fitting has a 37º flare sealing surface, no o-rings are necessary and don't use any type of sealant. We use a lot of these type fittings on our street rods, especially in the brake & fuel systems.
Mike
FICINJECTORS
10-31-2009, 08:48 AM
Mikenone of the fittings in the link provided use a o ring. this is the type of fitting that use an oring.http://fuelinjectorconnection.com/shop/images/uploads/thumbs/thumb_an.jpg
Thealien
10-31-2009, 08:56 AM
I have a different AN fitting question. What fitting would I use to go from a 3/8 fuel line with a factory flare fitting on the end? They aren't the same as NPT are they?
Thanks
Mark
FICINJECTORS
10-31-2009, 10:32 AM
Thanks
MarkNPT is national pipe thread.. no flares, heres what i like to go from OEM to AN
http://www.russellperformance.com/mc/adapt_fit/img/640850_lg.jpg
Thealien
10-31-2009, 03:01 PM
I already planned on using those on my fuel rail and regulator/filter. I am swapping a 5.3 into a 1972 Jimmy and have to do a whole new fuel delivery. I know they make a compression fitting to go from 3/8 or 5/16 hard line to AN Hose. I was just wondering if I bought a piece of fuel line with a factory flare fitting on it is there a fitting to go to AN? I just think something like that would be better than a straight compression
This is the closest I can find and says to aluminum tube?
HERE (http://www.summitracing.com/parts/EAR-165006ERL/)
FICINJECTORS
10-31-2009, 03:50 PM
HERE (http://www.summitracing.com/parts/EAR-165006ERL/)an to inverted flare is what you need.. i believe its on this page of Russell catalog
http://www.russellperformance.com/mc/adapt_fit/fuel.shtml
Thealien
10-31-2009, 04:32 PM
Thank you. Do you see any issue doing it that way?
