SUCK MY SS
10-23-2009, 08:15 PM
98 ls1 bare block w/ maincaps - 150
new mcleod single disc clutch... good to 650 hp... brand new oem flywheel and arp clutch bolts - 500
comp cams pro magnum 1.85 roller rockers... only used on the dyno...like new - 250
02 t56 slave cylinder w/ throwout bearing assembly... under 5k miles...- 50
manual pedal assembly for 4th gen f body - 40
lous short stick shifter - 20
stock torque arm - 20
stock lcas - 20
stock panhard - 10
stock front and rear sway bars w/ poly links - 50
stock front and rear shocks - 10 a piece
stock 806 heads complete minus rocker assembly... w/ valve covers - 70k miles - 75
OEM MLS 4.8/5.3 headgasket set - 40
jegster adjustable tunnel mounted torque arm - 100
stock ss muffler and tips - 30
ac condenser - 30
nx switch panel . purge.bottle heater,arm - 20
stock front springs from 00 ss - 30
stock camaro rear seats...one set leather one set cloth... both ebony - good condition - 50 per set
4l60e bell housing - 75
t56 tailshaft housing - 50
ls1 valley cover - 20
3 timing cover - 20 each
3 rear covers- 2 97-98 style 1- 99+ style - 20 each.
truck oil pan/windage tray/pickup - 50
i also have surplus of almost any bolt found on 4th gen fbody c5 vette gto..
as well as a bunch of stock parts, a bunch of stock exhaust manifolds as well as catalytic converters... i also have a bunch of random little parts as well as a couple cut up engine harness' , so if you need anything hit me up and i may have it.
if you have any questions feel free to call or text any time
626 354 5526
-Shant
ps. can post pics of anything upon request.
WTB -
tubular lower A arms for 4th gen fbody
solid engine mounts 4th gen fbody
braided nylon or stainless steel fluid line... i need -6 line mostly.
auto pedal assembly
new 10lb n20 bottle, or trade a 10 for my brand new nx 15 lb... must be new.
adjustable efi fpr... preferably 4/5 port with -10 feed -8 return
thanks.
low mileage TCI street fighter 3500 rpm converter for ls1/4l60e - 300 - SOLD
moser 12 bolt - 33 spline axles, eaton pro posi, aluminum cover,4.10 gear. comes w/ a pair of granatelli LCAs,welded on relocation brackets and sway bar perches, backing plates,extended wheel studs, e brakes work, no leaks. does not come with rear rotors or calipers..ready to run 1700 firm - SOLD
3 inch driveshaft for short tail th400 and 12 bolt into 4th gen .1350 yoke -200 - SOLD
unknown brand underdrive pulley... alittle beat up but still perfectly functional - 80 SOLD
oil pressure sending unit 99+ - 25 SOLD
new ect sensor for 97-98 corvette camaro 3 prong - 25 SOLD
complete set of oem head bolts for pre 04 ls1 engines - 50 - SOLD
pacesetter 1 3/4 " headers w/ 3 inch collector...race version... no smog...coating still in great condition...no dents w/ 3 in x pipe setup... magnaflow bullets, turndowns before rear axle - ready to run - 450 SOLD
2 upper condenser lines - 5 each SOLD
4l60e tailshaft housing - 50 - SOLD
stock 4l60e from a 2002 camaro ss w/ 32k miles... excellent
condition..complete - 350 - SOLD
ac compressor brackets w/ idler and tensioner pullies - SOLD
ls1 intake manifold - 50 SOLD
stock lcas - 20
stock panhard - 10
ac condenser - 30
626 354 5526
-Shant
WTB -
auto pedal assembly
thanks.
