Fueling & Injection - C5 1400fwhp fuel system.
Austin@HPE
10-23-2009, 08:26 PM
I need a 1400-1500fwhp fuel system for a 2002 c5 any help. Whats better twin pumps in tank or external. Prices all the usual. Im looking for over 1000rwhp through a powerglide.
Gordon0652
10-23-2009, 11:32 PM
I think you could never get away with a twin intake system at that power level.
I would think a stump tank with an external or two. 1400rwhp sounds like an FI car.
I have seen people wire two pumps so that one is always on and the second one comes on at XX boost level.
396375
10-24-2009, 01:36 AM
This is a good deal and should be more then enough.Nice guy to.
Good luck.
http://forums.corvetteforum.com/c5-parts-for-sale-wanted/2446913-fs-topmount-twin-turbo-kit-acp-stinger-hood-lots-of-fuel-parts-dewitts-rad.html
SSilverSSurfer
10-24-2009, 01:59 AM
run triple in tanks like the supra guys. tiago and mecham run them, and it works. if your FI and have an eboost2 you wire up the third to the extra aux port. fwiw tiago is running a 427 lsx with twin 76's and mecham is running a tti race kit with an 88mm i think
Lonnies Performance
10-24-2009, 11:11 AM
If you want a triple intank or a big external setup, I can help you out with a complete system for these cars.
Give me a call if I can be of help.
Austin@HPE
10-24-2009, 08:48 PM
We might have to do the triple pump to -10 feed i have twins in my 240 with 2jzgte. Thanks Lonnies
Lonnies Performance
10-25-2009, 11:19 AM
Call me whenever you are ready.
C5Fire
10-27-2009, 10:15 AM
Here is what I used on my C5. It's a custom setup that runs a single 255lph intank pump under normal driving conditions and kicks the Aeromotive A1000 on under boost with a hob switch. It's enough fuel to support over 1500hp and have great street drivablity. It also keeps the factory jet siphon opperating so both tanks work!
http://i514.photobucket.com/albums/t346/boostcrazy99/CustomC5FuelSystem.jpg
Nasty N8
10-27-2009, 12:51 PM
Lonnies and our setups also keep the function of the tanks working properly.
Austin@HPE
11-01-2009, 10:07 PM
Both look good dont think the a1000 will be big enough. But like the break down.
Frost
11-02-2009, 12:46 PM
You're right; it definitely won't. At our rail pressures those A1000s never move the amount they are rated for it seems.
cjg454ss
11-02-2009, 02:34 PM
i think twin walbros intank to y'ed together to a 420 bosch pump would get you to 1400fwhp. im going to try it here in the next month,
or
twin walbros to twin 420s, -1 walbro feed to a 420 , then y them both together at a -10 line, basically twin 340s and twin 420s, have one side on all the time and the other relay hooked up to the boost switch. that will move 1400hp worth all day.
Austin@HPE
11-02-2009, 09:16 PM
That's a good idea I might just take lonnies up on the big external like a aeromotive but the street elimanator with pump controller.
nnracing
11-02-2009, 09:22 PM
lonnies hooked me up with a double pumper full on kit it works great and awesome customer support.
sultan(ZR-1)KSA
11-03-2009, 04:17 AM
in my point of view i would go with a fule catch tank and have 2 bosch 044 feed the motor on -10 lines and -6 return
that will be my new setup
Magnafuel MP-4303 with a -10 feed to a y up front and -8 to to each rail will support what you want. One external pump to come on only in boost triggered by a hobbs switch which will be reliable and quiet when in normal driving conditions, simple and effective.
Nasty N8
11-03-2009, 02:08 PM
We have several systems to make well over 1400hp. Give me a call I can help you with the correct setup.
