Corvette Performance - WOT AC compressor Cutoff RPM
View Full Version : WOT AC compressor Cutoff RPM
Hayabusa02
10-24-2009, 07:54 AM
Can anyone tell me what the stock AC Compressor cutoff points are for a C6?
pittman
10-24-2009, 08:29 AM
I didn't know they had a cut off rpm ? I just dyno'd mine and forgot to shut it off. It ran up to about 6800rpm and never cut off. Ran again back to back and it only robbed 2 hp and 2 tq.
Pitt
Larry
10-24-2009, 11:43 AM
Here's the values for my 08. I've tried different values and the compressor does not respond. I cannot get it to turn off regardless of rpm or settings.
Hayabusa02
10-24-2009, 01:33 PM
Wow...I must admit that surprises me. I wonder if they have made redline across the board simply work for all the components on the newer cars. I'm building a GTM and have heard of people burning out their compressors not having a cutoff at high RPM.
Cool...thanks! If anyone knows differently, please let me know
GTODan
10-27-2009, 04:41 PM
Are they like the ones in the GTOs? They have kinetic clutches and simply disengage when too sudden of a rpm change occurs to protect the compressor.
~JOSHUA
10-27-2009, 05:34 PM
Does anyone know the cutoff for a C5? :lurk:
ysb02
10-28-2009, 10:17 AM
Stock ECU pull from 2003 z06:
Disable RPM: 4895
Re-Enable RPM: 4545
Disable TPS: 100%
Re-Enable TPS: 0%
