Cadillac CTS-V 2004-2009 - Best Transmission fluid
speedracer08
10-24-2009, 11:26 AM
I have an 04 cts-v and just hit 44,500 miles I might be having some syncro issues i dont kno for sure. If I replaced the tranny fluid would that help the issue? and whats the best transmission fluid there is for my car?
And is there a good warrenty I can buy for my car that will cover all this shit?:(
maxspeed96ct
10-24-2009, 02:21 PM
I put B&G in my rear end, for the trans I just used to recomend GM dextron 3.
Some use syncromesh for the trans but I think its alittle to thick and wouldnt do good in cold weather with the small internal parts of the T56..
CTSV_510
10-24-2009, 02:47 PM
I used Amsoil ATF and have been happy with it.
What are your trans symptoms?
speedracer08
10-24-2009, 03:53 PM
Sometimes I cant shift into 5th or 6th. Then ill go back into 4th and then it lets me hit 6th...
CTSV_510
10-24-2009, 04:14 PM
Well the trans fluid change is easy enough to do, so I would do that and also have the clutch fluid bled and changed. That would be the best start at tackling the problem.
speedracer08
10-24-2009, 04:52 PM
I just bought syncromesh tranny fluid and am changing it today
I do the clutch tomorrow hopefully ill see results
maxspeed96ct
10-24-2009, 07:48 PM
do u live in a area that gets below 32 degrees F ?
speedracer08
10-25-2009, 11:45 AM
I do but im moving to arizona in a week.. So I should be fine with the syncromesh. Right?
baalic
10-25-2009, 11:49 AM
Royal Purple makes a synthetic.....Haven't tried it yet, but only heard good things.
maxspeed96ct
10-25-2009, 11:52 AM
From what ive read yes, theres alot of threads in the transmission and drivetrain part of this forum .
take a look
