Drag Racing Results - First Time At The Track With My Z....
02SLOMARO
10-24-2009, 03:13 PM
So, i was a little dissapointed in my e.t. but the mph rocks. My mods are stock dispacement ls-1, tr224 cam, prc 5.3 cncd heads, ls6 intake, u/d pulley, slp maf, pacesetter lt's, off road y-pipe, borla cat back. I was running n/a. UNTUNED! I blame my lack of e.t. on running street tires and my junky stock clutch and clutch hydraulics, i.e. sticky ass clutch pedal. it sounded like i was running a old muncie rock crusher! oh yeah, full weight. including speaker box and tool bag!
http://i268.photobucket.com/albums/jj1/oldskoolracer81/timeslips.jpg
cdubbzz
10-24-2009, 03:33 PM
113/114mph in a m6 H/C car?....seriously do I have to be first here?
02SLOMARO
10-24-2009, 04:02 PM
what exactly does that mean?
mrbigjeep
10-24-2009, 04:07 PM
he thinks that sucks...
s346k
10-24-2009, 04:09 PM
seeings that you're untuned, i think you've got a decent trap speed. get a solid tune on it and a decent clutch and you'll be set. by the time you dial in the a/f and timing, and raise the limiter...that thing will fly.
02SLOMARO
10-24-2009, 04:56 PM
well, i think he sucks http://smiley.onegreatguy.net/bj3.gif. jk! what do heads cam cars with 4000lbs+ on street tires usually run!
i think for what it is, on street tires it did decent. i was hoping for 12.70's-12.80's on street tires. track temp was 35 degrees so i doubt it would have been possible. the yellow tickets "losses" were against a good friend of mine. we have played on the street numerous times and i absolutely rape him from any kind of roll. he ran consistent 12.90's all night. and yes, stock clutch and that damn 6200 rev limit is annoying as hell. it is my dd so i have not done anything to lighten it. i am working on a dd, and when it happens, i guarentee you i will have that thing completley gutted and stripped for next season. automatic with a stall for sure as well. the six speed is fun on the street, but on the track, i would much rather have an auto. i am changing my combination around so i will wait on the tune.
Magnet
10-24-2009, 06:10 PM
Looks good for having a lot of problems :) If you want it to shine get all the little stuff figured out, get a solid dyno tune, and put atleast a nitto on it and I bet you see 11.9-12.2 @ 116+ atleast!
COMNBYU
10-24-2009, 08:42 PM
Two words brother...tune & DA. Youre in AZ so conditions arent exactly optimal there, and you said you werent tuned.
Check out my sig for what a mostly stock LS1 will do in favorable conditions.
Given your mph, in perfect conditions you should be able to go some lowER 12's at least...
Dont sweat the haters...9/10 its just ignorance... :)
Jon
BADD SS
10-24-2009, 10:13 PM
et it tuned and problems worked out....
113/114 is slow for what you have
even 116 is slow
h/c, running right, driven right even with that small cam should be at least 118 trap speed...
BADD SS
10-24-2009, 10:17 PM
And how the hell are you 4000+ lbs????/ thats a new one on me, are you racing with the cheerleading squad in the back seat?
02SLOMARO
10-26-2009, 10:35 AM
even 116 is slow
well, stock clutch and stock clutch hydraulics. everyone knows what the clutch pedal does if you over rev it or try to bang gears. i had to let it rev down slightly before i could get it into the next gear. i swear i lost 2 tenths with every shift and a bang load of mph because of it.
if i am not mistaken a fully loaded and optioned out 02 will weigh in at around 3800. i have a speaker box, small as it is, it still probably weighs 25lbs, tool bag(20-25lbs) and me. i walk around at about 225. so i feel my estimate of 4000lbs + is not to unrealistic.
StreetSilverado
10-26-2009, 11:24 AM
+1
My car is on the heavy side at 3600-3700. No way he weighs in at 4000lbs.
02SLOMARO
10-26-2009, 02:49 PM
+1
-1
what does your car weigh fully loaded with you in it? what options do you have.
02SLOMARO
10-26-2009, 03:32 PM
but, it doesnt matter. i know i need to change some things up and fix some problems and head back to the track.
