Street Racing & Kill Stories - lost 2 of 3 to a twin turbo stang
View Full Version : lost 2 of 3 to a twin turbo stang
silverz28camaro
10-26-2009, 08:47 AM
http://www.youtube.com/watch?v=oiD7UVPhThE
I think this was some of the best runs i have done in a while.
My third run was my best, but the damn 4l60e was hitting the limiter on the 2-3 shift, well, i guess the car is going back into the garage for a rebuild.
That twin turbo gt runs its ass off!!!!!!!!!
silverz28camaro
10-26-2009, 08:49 AM
http://www.youtube.com/watch?v=TzV7lluPBYU
from his car
Super Slow SS
10-26-2009, 09:01 AM
Mustang seems to hook really well on the street for 650 ..
silverz28camaro
10-26-2009, 09:18 AM
Yeah the car has been 1.30 at the track on a trans brake, I was definitely up against a badazz car. Either way it was fun and It makes me think about a power adder...........100shot outa keep me in front......
silverz28camaro
10-26-2009, 09:19 AM
He did say he turned the boost up on the last run, but on the last run i hooked perfect and the tranny shifted fine. He was still coming up quick, good thing its 1/4 mile and not 1/2 mile
Sarge_13
10-26-2009, 11:07 AM
More info on both setups? Looks like both cars scooted out pretty well.
evangto87
10-26-2009, 11:34 AM
yes more info please.... i doubt its just a twin turbo stock 2 valve gt. Thing was realing you in like nobodys business. Good looking cars though.
sujomatt
10-26-2009, 12:13 PM
wow dude, ur maro gets out quick and that mustang seems to have CRAZY top end - great vids!
Stopsign32v
10-26-2009, 12:17 PM
Good lord he ran you down hard!!!!
silverz28camaro
10-26-2009, 01:20 PM
well in the vid it says what hp they are both running, he had et streets i had et street radials, mine is a stock ls2 bottom end, tv2 cam and home ported ls6 heads. he has twin turbos(bought the car that way) He can run anywhere between 16psi to 26 psi, and i think on the 26 psi setting it put down 900 from what he told me. He has a ported 2 valve heads with all forged internals, both cars have autos with stall.
98Zcarkid
10-26-2009, 05:40 PM
nice wheels brad who did you snatch those from lol
01z
10-26-2009, 06:04 PM
nice dig runs
mrbigjeep
10-26-2009, 08:02 PM
dang very nice vids...he was coming up quick!
and if he made 650 he isn't stock motor...just for those that said something about it
silverz28camaro
10-26-2009, 08:11 PM
They were off my bosses 53 chevy truck, it runs 11.8 on the spray, now he has an lq9 thats going in.
He was cool enough to let me burn those tires up
ballhawkdawk
10-26-2009, 08:25 PM
+1 to that. That thing came running back each time.
ULTIMATEORANGESS
10-26-2009, 08:27 PM
good races. that mustang has some serious power.
silverz28camaro
10-27-2009, 02:58 PM
yep. about 226 more hp then me.
stumprrp
10-27-2009, 07:49 PM
your car hooks nice on the street
ScreaminRedZ
10-27-2009, 08:43 PM
Good races and the vid came out great! Nothing wrong with losing to a badass car.
I'm really liking the Prostars lately. I may have to look into trading my Draglites for them...
silverz28camaro
10-27-2009, 10:46 PM
He actually gave me props on the runs, I know at the track that car has made some 9 sec passes. I swa some vids of it running 6.1 in the 1/8 mile!!
venom ws7
10-27-2009, 11:17 PM
Great runs both cars runs hard.
itsslow98
10-27-2009, 11:20 PM
nothign a 150 shot wont cure, but holy shit he was coming hard top end. made it look like you let off the throttle. 650hp sure sounds good but it opnly counts if you can put it to the ground, unless its a supra, then its ok if it makes 1500rwhp on a dyno and runs 13s.
silverz28camaro
10-27-2009, 11:46 PM
Well the first pass after hitting the limiter on the 2-3 shift I accidently shifted into nuetral. Same as second pass, the tranny wouldn't shift for a second(but didn't hit nuetral this time). And the last pass i let off slightly so I wouldn't hit the limiter, It did shift soomer, but seemed to be stuck in 2nd gear for a second or two.
The tranny and converter needs gone through again. I think if it would have shifted the way it should I would have won everytime.
Plus if you notice the oversized 28 inch tires on the car, they are not mine. My 26'mt et streets are wore out and my boss let me borrow his off his 53 chevy truck that runs 11.8 on spray. I could tell the bigger tires killed my gear ratio, but this guys was saying that there was no way a high 10 sec car cam beat his. Last race spoke for itself.
I did weigh my bosses tires after i took them off today and the front skinnies were only 6lbs lighter per wheel then my fronts(stock snowflaks) and the rear were 8lbs heavier per wheel, so I cam out a little heavier total and taller gear ratio then normal.
I'm hoping replacing my stock midpipe with a 3 inch setup will give me a little more topend
