General LSX Automobile Discussion - What did you break over the summer?
mcalus
10-26-2009, 12:13 PM
Well, over this summer a lot of parts went out on me this summer, so im just curious what everyone else broke?
For me: :emb:
Crack in radiator
Powersteering line sprung a leak
Rack and pinion was leaking from boot just before I put it away :(
Fog light bulb
Battery
Tires.... more or less my fault lol
I guess it could of been worse!
Not looking forward to getting tires, rack and pinion and an alignment in the spring. Guess thats just part of the game!
09jyounger
10-26-2009, 01:31 PM
10 bolt, T56, battery, and a set of drs.....its all good though, well worth it in the end
Ape Man
10-26-2009, 01:33 PM
-Crack in Rad
-Right side Headlight Motor
mcalus
10-26-2009, 02:03 PM
your kidding!?! thats a major bumme!
PewterScreaminMach
10-26-2009, 02:10 PM
3rd gear in July. Just got it back on the road yesterday. Yeah, I got lazy with the rebuild...
USArmyZ28
10-26-2009, 02:17 PM
Is it just me or do I have good luck? I have never broken anything in any of my fbodies.... well a window motor in my 00 Z28 and a leaking steering pump. But thats it after owning an fbody for 4 years...
1WICKDZ
10-26-2009, 02:42 PM
4L60e + converter
just went bigger and better :)
TooLateVTEC
Knock on wood, nothing.
It does need tires though...all 4, not just the rears.
Z28boy2000
10-26-2009, 02:49 PM
converter....which let to the tranny. but ya know what they say...go big or stay home
brians91formula
10-26-2009, 03:21 PM
In 8k miles...
window motor, and sail panel speaker. 10 bolt is getting weak tho
transamsam98
10-26-2009, 03:30 PM
does the bank count?
PewterScreaminMach
10-26-2009, 04:10 PM
List your mods and I'll probably be able to tell you why. :jest:
araber89
10-26-2009, 05:33 PM
Clutch at the end of summer so I just put it on storage coverage for the winter. Besides that battery and leaky power steering...
USArmyZ28
10-26-2009, 05:49 PM
uhhmm well my first fbody was a v6 firebird so i dunno if you wanna count that.
My second fbody was a 00 Z28 with 97k miles with bolt ons that I trashed almost everyday.
My current WS6 has trex cam, volant cai, 82mm TB, LS6 intake, pacesetter lts, dual exhaust dumped rear axle, 275 nitto's, few other things im sure I am forgetting. Makes 423rwhp through stock heads and "stock" LS6 intake mani. I am getting FAST 92/92 set up soon. Hopefully gonna get 440-450rwhp. I do baby my car though.
RsSean
10-26-2009, 05:54 PM
Window motor, exhaust hanger, Mass air flow sensor, pressure sensor too.
StreetSilverado
10-26-2009, 06:07 PM
-Motor (old heads/cam setup)
-Two 4L60E's
-A set of MT Dr's in less than 1000 miles
-Now I have an unknown problem with the cooling system.
billymz28
10-26-2009, 06:09 PM
A long list here.
transmission
2 valve springs
power steering line
a few wheel studs dam draglights
4600 dollars in damage to car due to thief that isnt smart enough to break into a fbody
1 flat tire
broke plug wire
1 cv shaft in daily beater car
battery in daily beater car
NSSANE02
10-26-2009, 06:17 PM
I had a nitrous backfire blow my MAF all to shit, blew the grill in the hood out and even spit some smoke and fire out the hood. All I did was chunk the MAF and switch over to SD and amazingly the car is still running strong. I think my clutch may be slipping a little too but other than that it's been a good year :)
aerojt
10-26-2009, 06:42 PM
Too bad you don't have a picture of that!
KILLER-LS1
10-26-2009, 06:48 PM
hmmm broke:
4 pistons,
3 rods,
head gaskets,
valves,
cracked the block,
killed my clutch,
broke u-joint,
cracked radiator,
broke motor and tranny mounts
broke reverse lockout solenoid,
broken reverse syncro
fried 2 rotors
broke my rear e-brakes
ummm im sure tons of other little stuff.
but thats what happens with 800 HP ;)
NSSANE02
10-26-2009, 06:55 PM
I know, it'd be sweet to see it breathing fire :lol:... I had a video but it happened around the 60' and you couldn't see anything cool.
mcalus
10-26-2009, 07:09 PM
Wow, some long lists you guys have!
PIZDETS
10-26-2009, 07:29 PM
Window motor, front speakers, trans tailshaft, bank account on upgrades
therobman
10-26-2009, 08:03 PM
a 10 bolt and the hearts of many mustang owners
gold98Z28
10-26-2009, 08:07 PM
is this sgm at fort sill? does he have a cobra?
my list is short this year. sad to say i only put about 5k on my car this summer. its usually tripple that. I got a late start from last years carnage tho. had to finish trans rebuild, clutch, driveshaft from last year. that was after everything in the rear came out the cover, tq arm wrapped around driveshaft(first one) and im not sure what else. this year...
axle and a spool i think are about it for this year, after i got the bugs worked out from last years carnage. oh and i just developed a bad oil leak over the weekend. not sure what that is yet.
but its not over yet. gotta street car showdown in two weeks. will report back after i break something new. lol
BlueBird346
10-26-2009, 08:11 PM
I snapped a driveshaft in July.
USArmyZ28
10-26-2009, 08:23 PM
Nah hes in Fort knox and drives a 05+ mustang.
Nsty98LS1
10-26-2009, 08:41 PM
all i had was a nitrous backfire that took out my LS6 intake & oil pressure sending unit. i was told i had a huge fireball fly out from under the car. i was pissed that i didnt get to see it!
transam69230
10-26-2009, 08:51 PM
Stock rockers, a set of MT drag radials, I think that is pretty good for this year as it is usually more!
araber89
10-26-2009, 09:02 PM
There are a few of you guys that I am glad don't live close to me. Those are scary lists.
01FbTaWs6
10-26-2009, 09:05 PM
2 rod bolts
2 rods
2 pistons
windage tray
cracked block
torn up crank
2 bent valves
oil pan
all from 1 rod letting go at 7krpm.........
zzz28
10-26-2009, 09:20 PM
its been a long year, 4l60e, a/c went out, door speakers and rear hatch speakers, both window motors, power lock switch, and had a vacuum leak
Mr CHI
10-26-2009, 10:17 PM
Nothing. :)
TJ
10-26-2009, 10:25 PM
wore out some rear springs, broke a 9", twisted off a driveshaft yoke, killed my built tranny, all at different times.
00fastta
10-26-2009, 10:52 PM
cracked the radiator in my landcruiser if that counts...I've been babying the trans a little too much for now
Kevin01Z28
10-26-2009, 11:01 PM
Totaled my 2001 Z28 :(
Now my trans is beginning to take a crap :barf:
Been a rough year
02_camaroz28
A/C Went out. Bent an axle. Radiator Hose. Broke the corner of the block off when the starter broke and put it in a bind... Time to pull the motor and rebuild :nod: Oh and the tranny slips lol
Detoxx03
10-26-2009, 11:09 PM
Window Motor
Blew a Tire
DRL Sockets
Antenna
riceburnerZ28
10-26-2009, 11:15 PM
T56 grinding in second gear
clutch slipping bad after one burnout
brake master cylinder failed while driving
emergency brake cable broke
Detoxx03
10-26-2009, 11:17 PM
Oh yeah I needed a new oil drain plug cause I stripped mine
1slo_camaro
10-26-2009, 11:22 PM
3 motors, one tranny, rolled a car, totaled an 05 silverado, 2 sets of street tires. nail in a Mickey T DR, lots and lots and lots and lots of bolts. lol the bolts are the biggest bummer. lol
jimbo98z
10-26-2009, 11:34 PM
Bearings in the 12-bolt
Driveshaft (Not really broken, just fed up with the vibration, ordered a new one)
Somehow parking brake lever (on the brake backing plate, not in the car)
HumanNipple
10-27-2009, 12:17 AM
2 window motors, O2 sensor is dead, my rear rotors finally needed replaced and my flux capacitor won't get me to 88 mph
slayerized6
10-27-2009, 12:33 AM
my upper dash had its last battle with the sun; decided to split into 5 pieces
APG12
10-27-2009, 12:48 AM
t56, clutch, hydraulics, 10 bolt, headlights, turn signal, tires
02_camaroz28
10-27-2009, 12:56 AM
I think that would irritate me more than anything else lol
slayerized6
10-27-2009, 01:09 AM
i was pissed! one day my dash was fine, the next day it was in 5 pieces
$200 for a new OEM dash, and $200 for tints, and hopefully i will never have to worry about that again
CarolinaTA
10-27-2009, 01:15 AM
Totalled my 95 Z-28, bought my 99 Trans am, only broken things are a head light motor which will be fixxed soon and my passenger side window motor.
4150
10-27-2009, 01:17 AM
Slave cylinder went out which meant dropping the tranny. Of course it snowballed since I decided I may as well replace the clutch/pressure plate/flywheel while the tranny was out and also replace the clutch master cylinder just to be safe.
02_camaroz28
10-27-2009, 01:35 AM
Yeah that sucks! I invested in tint not only for the looks but to help save my interior.
cody161
10-28-2009, 12:14 AM
totaled 94 z28. then got a 2000 Trans Am here is all the stuff from this summer
window motor
t56
front passenger rotor
A/C
Clutch Master Cylinder
ratcheting mechanism on ebrake handle
Adam86
10-28-2009, 01:21 AM
Hmm well I just hit 100k and my right blinker doesn't work and my passenger low beam is burned out. Other than that, we're ready to roll! :)
NSSANE02
10-28-2009, 10:17 AM
I just hit 90k yesterday, and I think my fuel pump shit on itself :(
itsback08
10-28-2009, 11:26 AM
i didnt break anything thank god. but it really didn't matter because i stripped the car down to nothing to change color and paint and clear the underside of the car and put a cage in. an ass load of work for no reason lol
jimbo98z
10-29-2009, 10:30 PM
Damn Lybians...
01 Trans-Am WS6
10-30-2009, 12:44 AM
Wow where to start...
August my Spec Stage 3 started slipping. Had to pull trans again, however clutch looked perfectly fine? Threw in a new slave cylinder and flywheel and oh course along the way ran into a million problems. (Mind you all while working on our backs in my rock driveway with the car on jackstands.) One night putting the trans back in somehow the metal rod comming off the slave cylinder snapped. The something didn't quite line up and we were not able to bleed the slave. Had to pull the trans again and realign the clutch. Put it back together and drove it for 1 week and 1 day...
Then a friend bought a 93 Camaro Z28 with work done that supposibly ran 12.60's. He called me out b/c I ran a 12.56 in my car. Well we raced. After I put 6 cars on him my driveshaft blew out my c-clips on my driveshaft, sent my driveshaft smashing into my tailshaft casing on the T-56, completely cracking it IN HALF. I'll post pics of the damage. Also put a nice dent in the driveshaft meaning I needed a new one. Had to pull trans again to fix it and once again ran into a million more stupid little problems. (I.e. slave cylinder bolts stripped so had to get new ones tapped, new tailshaft case was not fully milled and had to get 4 shifter holes tapped.) Finally got it all back together and had a hard time keeping my brackets tight, finally got that figured out now I learned I need a torque arm....plus an alternator. Just got a new battery 3 days ago...ohh blew out a whole bunch of speakers...and 2 new rears tires and need fronts soon. Last thing lol I need a new 02 and extention.
http://i916.photobucket.com/albums/ad2/01Trans-AmWS6/Picture1212.jpg
http://i916.photobucket.com/albums/ad2/01Trans-AmWS6/Picture1211.jpg
http://i916.photobucket.com/albums/ad2/01Trans-AmWS6/Picture1210.jpg
Plan is to fix it up this winter, make it alot nicer of a car overall.
Hawk170
10-30-2009, 12:49 AM
still not running from last summer ...
JPCrazyLegs
10-30-2009, 01:03 AM
Window motor, torque arm bushing, sail panel speaker, oil drain bolt head stripped on me.
Man you guys must really rip on your cars lol.
