Fueling & Injection - EV14 injectors w/ ls2 intake
Woody73z
10-26-2009, 08:03 PM
Ok so i bought these 1000cc ev14 injectors and I thought they were saposed to drop right in.... They seem to short. When i bolt the rail onto the intake the injectors feel loose then you can push on them and they will " snap" in but come back up pretty easy? Is this normal? Do I need something else? Thanks for the info.
FICINJECTORS
10-27-2009, 01:14 AM
what o rings are on the bottom.. if they are green or black 14, you need to get ls2 or ls3 16mm bottom o rings,, they are orange.. if you have the stock ls2 injectors you can swap them. call me if you need them
Woody73z
10-27-2009, 06:01 PM
They are green yeah I need the bigger ones thanks for the replay i will give ya a call!
