Fueling & Injection - How do i set up a sump fuel tank
View Full Version : How do i set up a sump fuel tank
devilssled
10-27-2009, 03:50 AM
I need some help, im going to build my own fuel cell and i need to know, how how do i set up the correct sump for a extrenal fuel pump? and how to make the baffle to stop the gas from sloshing. Also witch is better, the intank dual walbero's or externals? please help nasty
Nasty N8
10-27-2009, 12:54 PM
We offer a race fuel tank that is completely ready and setup properly for external sump fuel system. Dual pumps are a better street setup to 1000rwhp race tank and external is better track setup for big HP.
devilssled
10-27-2009, 01:09 PM
I WANT TO BUILD MY OWN FUELCELL i know You sell your tanks thats why i asked for your help! if i had money just to spend i would buy one from u. I can build my own for about 100$ so can u explane to me, or show me somewhere to learn how to set up my own sump tank and how to make the gas not slosh around. Thanks for your time
devilssled
10-27-2009, 02:18 PM
Anyone ? It cant be that hard.
Nasty N8
10-27-2009, 02:31 PM
You would need to weld in a baffled sump to your tank without it leaking. clean, acid the inside and seal it so it will not rust from welding.
devilssled
10-27-2009, 02:46 PM
And what would thei baffle look like? i will use 1/4" thick aluminem and a tig to weld it up
devilssled
10-27-2009, 10:20 PM
ARE u not going to help cause u wont make money or what
jonathan_ed3
10-28-2009, 12:21 AM
Fuel Cell's aren't particular to LS1/F-Body cars so look on google and other forums for some ideas.
If you can Tig Aluminum, you must have some sort of fabrication qualifications that would enable you to build what you're asking.
Here's a fuel cell for a buggy http://www.4wheeloffroad.com/projectbuild/131_0810_how_to_buid_a_rock_buggy/photo_03.html
they're using an internal pump. If you want to use an external pump you would need to sump it.
There's some great info in thrs thread here:
http://www.clubcobra.com/forums/showthread.php?t=88435
Here's some info on a sump...just apply the ideas to your "cell" instead of this gas tank.
http://www.moparmusclemagazine.com/projectbuild/155_0401_1967_plymouth_valiant_fuel_system_upgrade/index.html
devilssled
10-28-2009, 07:52 AM
Thank u for taking the time to post up
F-Body_Kustoms
10-28-2009, 04:28 PM
Can any one else help, there is not enough info there to help with what i need thank's. I want to know how to make a bafffle in the tank to stop the gas from splashing around. I have googled it and nothing comes up.
