Tools & Fabrication - what car jack are you guys using??? looking at a HF jack..
z28_n_tx
10-28-2009, 12:09 AM
i searched..but did not come across any reviews for the following jack for $59.99
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=91039
98Z2885
10-28-2009, 09:53 AM
I have one of those, they are junk. The first one was broken when I opened it. Second one tried to turn over jacking up my 67 camaro. Another guy I know, we were at autorama he was jacking up his 68 chevy truck and it turned over the wheels were off of it too. It was a mess. I would look into craftsman. There is nothing wrong with harbor freight stuff, I have alot of tools from them. There jacks just suck. IMO.
billyb
10-28-2009, 07:34 PM
lol i got that one and it's fine had it for 3 years now and i also have this onehttp://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=94629 i use it for my quick lift !!
KurtRardin
10-28-2009, 11:57 PM
Ive got this one: http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=92782&CategoryName=&SubCategoryName=
Its the low profile aluminum jack. Its low enough to get to the Kmember with stock ride height.
z28_n_tx
10-29-2009, 12:18 AM
yeah forgot to mention my car is lowered and i need a jack that will lift the car high enough to where i can put it on jack stands. I have the gm jack stands that are sold at walmart if that matters.
tahnsk
mitchntx
10-29-2009, 06:05 AM
15 years ago, I began messing with cars again. Family commitments began to dwindle as my kids began graduating and moving out.
I bought a couple HF jacks and they was OK, but didn't last very long as has been pointed out.
I bit the bullet and bought an AC DK13 jack. That was in 1999 and it still works like new today.
My old street car was lowered with Eibach Pros at the time and I could slide this thing all the way to the K-Member and jack away. It will lift the car over 2 feet off the ground. No more stacking 2x4 blocks to get a trans out.
Here is kind of a tongue in cheek floor jack shoot out ...
http://www.vorshlag.com/tech_jacks1.php
Some very good, side-by-side comparison data, though.
The AC line-up is no longer available
http://www.asedeals.com/hydraulicjacks2.html
But, they claim this is just as good as the ACH jacks.
http://www.asedeals.com/Ranger_floor_jacks.html
$360 delivered to your door.
trippinholyman
10-29-2009, 03:33 PM
i just bought one today. i was usin a jack i borrowed to do an oil change and with the way the front of the car is i couldnt get the handle straight up enough to actuate the release mechanism. so, i went to HF and bought a jack. it was 89.99 and its pt num. 67022. 2 tons, low profile and release can be actuated in any handle position. its nice and heavy and looks like it has a good sturdy frame. 2 7/8" minimum height, lifts to 20 1/16" maximum, so you can use it to do most stuff without need to use wooden blocks (unless you are jacking engine by the pan or need a few more inches like for headers :P)
i understand what you mean about the HF jacks seemingly tipping over - I bought a cheapo one to change tires with and used it for an oil change when i had nothing else around once (the one that costs 28 dollars or whatever, little compact red 2 ton jack with the yellow handle) and i jacked it up too high and the frame bent. waste of money. if you buy a chinese one for like 90 bucks though if it isnt broken in the box then it should work for a few years at least. i have to see if you can get the seals and stuff to rebuild them, was just curious about that. also HF around here at least offers extended warranties, like 20 bucks for 2 yrs and you can return for a new one no questions asked.
what part number jack did you use on the 67 and 68, 98z2885? was it mine? :/
Camaro Junky
10-29-2009, 04:39 PM
Mine broke with the car in the air.... That was a huge pain in the ass. I took it back. They are junk.
01ssreda4
10-30-2009, 09:49 AM
2 years with one, no problem. Its not my daily jack anymore though.
Myrdhyn
10-30-2009, 03:37 PM
http://www.sears.com/shc/s/p_10153_12605_00950139000P?mv=gr
Yeah, it is probably a bit overkill for working on one f-body and one cobalt, but I love it. I also have a smaller 2.5Ton walmart floor jack as a backup/spare/whatever. I need to pickup a second pair of jackstands and a set of ramps before I'll be happy.
Jeff Smith
10-30-2009, 04:51 PM
I copied from other forum I posted:
I made order Arcan XL35 (#144236) 3-1/2 ton and can liftup ~20" & 1 yr warranty thru NorthernTool.com. It costs me 149.99 plus s/h $59 to my "business garage"= ~ $227.
I had been researched on floor jack thru few forums/consumer reports/others. I hope so, I made choose the best jack lif-up>> Arcan XL35. :rock::rock:
I copied from Northern Tool.com:::::
http://www.northerntool.com/webapp/wcs/sto...45429_200345429
8 out of 8 would recommend to buy......
DopeFedZ
10-30-2009, 06:32 PM
I have the one below. My car is pretty damn low and I can still reach the kmember without having to drive up the car on anything to get the jack under it.
http://www.asedeals.com/service-jacks-omega.html
V8Rumble
11-01-2009, 03:00 PM
When buying a jack, I literally can't help but remember a guy that I worked with several years back. He was working under an old ('50s or '60s) Cadillac when it came down on him. He was a member of the plant maintenance crew, so you'd frequently see him walking from one place to another - and for a few weeks there, he was walking really slowly & carefully...
Remembering that has made it really easy for me to avoid buying cheap Chinese-made crap (even though I always use jack stands!).
Just my 2 cents...
daryn c
11-02-2009, 11:20 AM
i got my truck jack from autozone (torin 3 ton).. paid 150
my buddy has the light weight aluminum one , also from autozone he have lifted some heavy chit with it and it does great! prices usually run from 100-130 for it depending on when you go
CranMaro99
11-03-2009, 01:27 AM
That's kind pf pricey (not for what it is, but for me personally) but it may just be worth saving for. That's exactly what I need.
PewterScreaminMach
11-03-2009, 04:13 PM
http://www.sears.com/shc/s/p_10153_12605_00950239000P
Craftsman 2-ton low profile jack from Sears. I bought it last year before reading the terrible reviews but everyone I know that has one (including myself) has had zero issues with it. I got it on sale, as well.
tim99ws6
11-03-2009, 04:36 PM
We've got two we've used in the shop as well.....never a hint of a problem.....Maybe people are killing the hydraulics by running out of fluid?
9t8z28
11-03-2009, 09:14 PM
I have the same one. I thought it broke but it turns out that it just needed to be bled. It works great and I put it through its paces. I use it a couple of times a week and have had it for about a year now.
bearcatt
11-03-2009, 10:43 PM
http://www.harborfreight.com/cpi/photos/94600-94699/94641.gif :devil:
MustangEater82
11-08-2009, 04:35 PM
Not to be rude but your opinion of Jacks went out the door if you suggested a Crapsmen...
Do any sort of search here or a google search of Craftsman jacks and their "quality" Worst jack I owned, seals died out in like a year and I rebuilt it, seems to be ok now, but crap...
as for the harbour freight jack in your link, I have had 0 issues, noen what so every with that jack, used it nearly weekly when I was bigger into cars been sitting alot less now that I am not and no issues, still.... Surprisingly most people have had good experiences.
I would buy 5 of those before I wasted a dime on a craftsman.
I have been a Horrible Freight, I mean Harbor Freight connoisseur for years(prefered place to buy throw away tools at my work) They do sell mostly junk, but 1 out of 10 things they sell does its job, and sometimes better then its competitors.
I have full confidence in their jacks.... (well as much confidense as I can have in a hydraulic jack, ALWAYs use stands)
for all the stories of flipping jacks, sounds like inproper lifting, not a bad jack, the frames are just nearly identical to any other similar jack, if its goign to fail it would be the hydraulics.
MustangEater82
11-08-2009, 04:38 PM
If I was looking at jacks again I would take a look at the northern tool ones.... they looked pretty solid but last time I was at one I never really saw a aluminum one.
99'CajunFirehawk157
11-08-2009, 05:27 PM
Are their any jacks that arent made overseas anymore?
EDIT: I own a Michelin jack I bought @ Sams about a year ago, it works good but I am sure its made in china...
waltsfastz
11-08-2009, 05:35 PM
Yes, however I forgot what their name was. last time I checked they were somewhere in the 450- 500 dollar range.
As for a good jack matco Sells"the Beast" 3.5 ton jack. We have 2 of these and have put them through pure hell. We have had tractor rears to fall off of oneon top of it and it didnt hurt it.
NAPA sells the same jack but it is only a single stage but about 100 bux cheaper.
