Midwestern Members - ANyone have a crank pully/balancer installer in MN?
imnmbr1
10-29-2009, 02:47 PM
Anyone have a crank pully/balancer installer in MN? Let me know if I can rent it.
Duffster
10-29-2009, 02:49 PM
You can always take a 2x4 and beat it on to the point where the old bolt will pull it on for you then swap in the new bolt before torquing. . .
imnmbr1
10-29-2009, 03:15 PM
Yeah don't really feel like removing my condenser to beable to hit it hard enough
TWS
10-29-2009, 03:19 PM
Don't know about MN, but down here Autozone stocks an installer that I have used a couple times. I recall at least once adding a spacer because my ATI Damper hub was too deep to use the tool without it, but otherwise it worked fine for me.
Duffster
10-30-2009, 03:23 AM
I just remembered, there is supposed to be a longer bolt like the stock one (diam. & pitch) that you should be able to get for about 5 or 6 at Lowes/Home Depot/Menards. . .
vandejr
10-31-2009, 08:28 AM
u can use a ls7 stock crank bolt.thunder racing has them.there like an inch longer then ls1,and make sure to put a new ls1 crankbolt. dont use the same one.
