Generation IV Internal Engine - Stock LS2 Connecting Rod strength
View Full Version : Stock LS2 Connecting Rod strength
setxws6
10-30-2009, 03:30 AM
Can anyone give me any info on how much rwhp stock LS2 rods can take or are rated to? I've searched but haven't found much info. I know they are stronger than the stock LS1 rods, but wondered by how much. Thanks.
69LT1Bird
10-30-2009, 07:02 AM
Who told you there was a strength difference? The difference is the old rods are pressed pin and the new rods are floating pin. Same powdered metal design and fractured cap technology.
From the GM Performace Parts catalog: The LS3 obviously makes some great horespower with mods. The rod bolts are the weak link.
Connecting Rods and Components
C. 12568734
1997-2004 Connecting Rod
• Connecting rod for use on all 1997-2004 production
Corvettes and 1998-2002 Camaro/Firebird with LS1/LS6
• Press fit design
• 6.098" C-C length
• Sold individually
12617570
Connecting Rod (not shown)
• Connecting rod used in 2005-2007 LS2 and 2008-2009
LS3 engines has bronze bushing
• 6.098" C-C length
• Sold individually
hellbents10
10-30-2009, 08:13 AM
The LS2 rod is stronger. They will bend and then break at roughly 950-1000hp. That is if you have good fuel and a good tune. I think Frank02l (I forget the screen name exactly) was running 5.7's in the 8th and he broke a couple sets running good fuel with a 47-88.
The older rods have a smaller cross sectional area and are not as strong. I agree that most failures people see are do to rod bolts though.
01FbTaWs6
11-02-2009, 07:55 PM
so, how much power and rpm can a stock LS1 rod hold??? How much for a stock LS2 rod. lets say both with ARP rod bolts. Im looking for repeated use numbers, not just "oh they can touch 7800 a couple times" Thanks in advance!!!
Hans Grüber
11-03-2009, 03:07 AM
Does anyone know the weights of the early and later rods?
