Drag Racing Results - In Car Video of Formula on 28 inch Slicks
N2RACINGLS1's
10-30-2009, 09:30 PM
Took the Formula to I-40 Dragway in Crossville with the 28X10.5X15 S M/T slicks instead of the 26X10X15 S M/T slicks.
The car actually picked up ET and MPH! I have a little more tuning to do on the suspension but I was very pleased!
N2
http://redirectingat.com/?id=262X412&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DjsO QQBU90Kw
robsquikz28
10-30-2009, 09:34 PM
pretty cool vid man
1BAD_LS1
10-30-2009, 09:43 PM
car moves out! Nice video
speedshifterNC
10-30-2009, 09:57 PM
what is your suspension set up?
BADHAWK51
10-30-2009, 10:40 PM
Looks like you went through the traps at only 6000 rpms with the 28's.
N2RACINGLS1's
10-31-2009, 09:01 AM
I Have no problem with sharing my efforts!
I have installed poly mild steel tubular Spohn LCA, Drag sway bar, Torque Arm, K-member, Upper and lower A-arms and QA1 R shocks with 275 lb. springs in front only! I made my on travel limiters. I have Comp Engineering shocks and stock springs in rear! I also have airbag in the right spring which I had before I added the Drag sway bar.
I have the front shocks set on full loose. I have the travel limiters set to allow 4 inches of travel on the front at this time! I have the rearend angle set at -2 degrees! ET Drags are set anywhere from 15 to 16.5 lbs. depending on track conditions. I have the rear airbag pumped up to 15 lbs.
I Footbrake to 3,000 RPM's and wait on the last yellow stomp on the gas and go!
Hope this helps!
N2
I would agree somewhere between 5,800 rpms to 6,000 rpms it should allow me to increase the nitrous shot at the 1/4 mile tracks which was my goal!
N2
JaSSon
10-31-2009, 08:33 PM
Sweet vid! Man, I need to get to the track.
STOCK12SECZ
10-31-2009, 10:24 PM
Very nice!
n2ocamaro
10-31-2009, 11:17 PM
Nice pass. I am planning on switching to ET drags next year. My radials are too inconsistent. I am looking at the 28x10.5x15.
02_camaroz28
11-01-2009, 01:42 AM
I noticed you were on 346CI and that is my goal with my current build im wanting to start very soon. I was curious if you would care to share what your running on your setup? What Heads, Cam, Intake, Stall, Gears, Pistons, Injectors and Pump, Valve Springs etc. etc. I see your putting down some good times and was curious to know if what im looking to do was close to your setup. Thanks
N2RACINGLS1's
11-01-2009, 04:50 PM
I think you will like them I am a believer now!
N2
Take a look in the 10 second section and look at Good 3,000 RPM Launch Photo thread that I have I think most everything is in there if not I will send you a PM!
N2
02_camaroz28
11-02-2009, 12:41 AM
N2
Thanks Sir!
N2RACINGLS1's
11-02-2009, 08:10 PM
You are welcome! Good luck on the build and be safe at the track!
N2
ndfrsd6
11-03-2009, 10:44 AM
good to see ya switch to the 28's .....:D i think they will help you much more the more you go faster
SPEED#1
11-05-2009, 04:10 PM
that car is sick and damn nice vid too.
N2RACINGLS1's
11-06-2009, 09:44 PM
Thanks it has been a lot of fun for sure!
I do think they are going to help me when I up the nitrous down the 1/4 mile!
N2
nocooler
11-08-2009, 10:01 AM
Nice run!
I wondered why it was so rich, then I saw it was on the dope.
98TA6.0
11-08-2009, 10:13 PM
just curious but did you have to do any body work to get the 28s to fit? i am planning on doing 28x10.50s but concerned with rolling fenders and beating the hell outta my body. what backspacing is your rim? thanks
stoverz28
11-08-2009, 10:41 PM
You have balls my friend. It looked like the car took a turn towards the wall on the launch but you stayed in it anyways!
Looks like a nice car, congrats on your times. Turn it up to a 150 and post the vid of your 9 sec pass for us.
N2RACINGLS1's
11-09-2009, 07:02 PM
Nice run!
Yes that was on a 75 HP dry shot!
N2
Well I have a Formula which does not have the extras that a TA has. I had to move the rear end forward 1/4 inch and take a hammer to the inner fender wells in front of the rear end, no fender rolling I do not have the car lowered stock springs and rubber hose in place of the isolator. I have 7.5 inch backspacing for the 15X10 wheels. I hope this helps!
N2
Yea it has always launched straight on the 26 inch tire but with the 28 inch tire it was a little bit different. I tweaked the suspension a little bit more after that outing I think it is ready to go now! The main purpose for going to the 28 inch tire was to add more nitrous so we will see what happens.
I was surprised to see it pickup all the way across the board with the 28 inch tire that is for sure!
N2
N2RACINGLS1's
11-14-2009, 10:56 PM
Went to 411 today to make sure the tweaks to the suspension worked!
The track came around late in the afternoon! Who saids that track does not hook?
Here is a 1.378 60 foot video! I am really liking the 28 inch tires!!
http://www.youtube.com/watch?v=1uLpg0ZHjFQ
N2
qwk93ta
11-15-2009, 06:41 PM
Nice Videos....you have a bad ass ride!
N2RACINGLS1's
11-17-2009, 07:38 PM
Thanks qwk93ta the car has been a lot of work and fun! I am really surprised that the car picked up all the way across the board with the 28 inch tires!!
I am looking forward to going to the 1/4 mile track real soon!
N2
stumprrp
11-21-2009, 12:26 PM
car hauls ass, what converters in that? its flashing super high and i love it
