non-LSX Parts For Sale - turbos, nx bottles, callies crank, comp cam
ssinister550
10-31-2009, 05:23 PM
i have for sale two basically brand new turbos, two 15lb NX nitrous bottles in good condition, one callies compstar 4.000" crank and one comp custom grind cam
TURBO #1, $800 shipped: freshly rebuilt turbonetics t-76 turbo. 76mm compressor wheel inducer dia. w/ 4" inlet and 2.5" outlet cover. p-trim turbine w/.81 a/r, t4 flange, on center turbine housing w/ 3" round 4 bolt discharge. this thing alone will support up to 1000 hp and it features the "HP" compressor wheel capable of providing 35+ lbs boost efficiently. this turbo made over 700 whp on a heads/cam ls1 T/A w/ 9 psi.
good for engines displacing between 3.8 and 8.2 liters...
TURBO #2, $550 shipped: freshly rebuilt garret/ airesearch 55mm t3/t4. 55 mm compressor wheel inducer diameter, compressor cover has a 3" inlet and 2" outlet. also a p-trim turbine w/ .81 a/r, on center, t-4 housing with 3" round 4 bolt discharge. this turbo made 440 whp on a 99 ss camaro with a basically stock ls1 @ 8 psi. this turbo will support up to 500 horsepower on engines displacing anywhere from 3.0 to 7.4 liters.
BOTTLES $180 shipped each: two Nitrous Express 15LB nitrous bottles.
FORGED CRANK $900 shipped: 1 callies compstar 4" forged ls1 crankshaft brand new in box
CAM $150 shipped: i have a barely used comp custom grind cam in perfect condition. specs are 230/226 596/585 on a 113 LSA. yes it is a reverse split which means it is ideal for turbo applications but will also make good power in N/A apps.
