Pontiac Firebird 1967-2002 - security light flashing car wont start
matt01ws6
10-31-2009, 10:24 PM
my security light is flashing replaced the ignition switch still doesnt work. any ideas
99huggerorangeZ
10-31-2009, 10:37 PM
try a different key, the resistor in the key may have failed.
matt01ws6
11-01-2009, 02:19 AM
ive tried both of my keys. i guess ill go get a new one made and see if that fixes it.
LS1W66
11-01-2009, 09:20 AM
VATS Bypass is the cheapest and easiest way to solve your problem.
Check this link and scroll about 3/4 way down to find the Pass Key II Pellet Values
http://shbox.com/1/4th_gen_tech2.html
And heres a quick easy to understand diagram of the Mod
http://shbox.com/1/vats_bypass.jpg
I had Security Light Issues for yrs until one day it wouldn't start for over 30 min. So I finally did the Bypass and have had NO issues since.
peechy
11-01-2009, 02:17 PM
when mine did this i could either hold the key on start and in about 4-5 seconds it would start or i would lift the clutch a hair and push it back in and keep trying the key
WhiskeySierra6
11-02-2009, 01:22 PM
+1 on the VATS bypass...had to do mine. Wasn't very difficult.
98warbird
11-02-2009, 05:21 PM
+2 Yes sir that is the way to go, I have had it done for 2 years now.
Saturn5
11-02-2009, 08:39 PM
Bypassing it gets you running, but what's the root cause of the problem? Is it the lock cylinder? Key?
Apostle
11-02-2009, 10:27 PM
I'm having the exact same problem. Thanks for the info!
matt01ws6
11-03-2009, 12:50 AM
exactly mines at Pontiac getting fixed tomarrow. i tried the bypass didnt work so i said screw it
WhiskeySierra6
11-03-2009, 01:40 AM
Could be the pellet in the key or the wiring. One thing you can be sure of is it will be expensive if you take it to the stealership.
Super-Bat
11-03-2009, 02:49 AM
Yep. Had mine replaced a month or so after I bought my car. ~$300 install. Not fun on my wallet. :(
I've never done the bypass, and don't think I'd recommend it. At least, not as a permanent fix.
matt01ws6
11-03-2009, 04:52 PM
just picked it up today, clutch position sensor was bad and key cylinder. $550
