LSwhat???
10-31-2009, 10:53 PM
full weight no reduction ac works...daily driver..
motor:
TSP 408 stroker
wiseco -10cc pistons with wiseco steel top/napier 2nd ring set
eagle ls1 h beam rods with arp bolts
callies dragonslayer crank arp main stud kit
prc 237cc heads fully ported cnc heads arp 12pt. head stud kit cometic .045" thickness head gasket
fast 92/92 intake and tb. fast fuel rails
TSP ms4 cam prc aggresive springs yella terra rockers stock ratio
kooks LTs 1 7/8"x3" open headers
racetronix high output fuel pump
42lb injectors
hp tuners tuned by myself
drivetrain: stock t56
monster lvl 3.5 clutch
fidanza lightweight flywheel
slp skipshift eliminator
pro 5.0 shifter
moser 12bolt 4.10 gear 3 channel abs 33 spline limited slip posi
mickey thompson et streets
msd 2 step set at 5000rpm
suspension:
BMR tubular k member
UMI shock tower brace
UMI 3 point harness bolt in subframe connectors
what do you guys think of this build nd what do you think of horsepower numbers nd 1/4mile times...
motor:
TSP 408 stroker
42lb injectors
pro 5.0 shifter
suspension:
