LS4 Front-Drives 2005-2009 - Dyno numbers, sound about right??
crazyjoe
11-01-2009, 01:17 AM
Was at a buddies this evening and we decided to slap the GXP on his dyno for fun. Only made two pulls, one in third and then again in second. First pull was in 3rd and it hit the 140mph limiter way before redline and made 230.x whp and 250 tq. So, we decided to make a 2nd gear pull to avoid the speed limiter to at least be able to pull to redline, it made 239.x whp and 250.x tq. Does that sound about right for a bone stock GXP with 36K miles? I'm curious if it could've made a few more hp in 3rd if it could've pulled to redline. Thoughts?
Joe.
JP_GXP
11-01-2009, 01:35 AM
~298 bhp and ~312 ft/lbs sounds about right, factory tests were 300 hp @ 5600 rpms and 323 ft/lbs @ 4400. I think second is the good dyno gear, I plan on getting a dyno tune next year, too.
Mels SS
11-01-2009, 08:12 AM
JP are you sure about those numbers?
crazyjoe
11-01-2009, 09:25 AM
I did a search and it seems that my numbers are within range of most stock LS4's, so I'm cool with the fact the car is making the power it should be. I really want to wake this thing up though, where are those damn headers, lol!
I'm going to be running the car in the 1/4 mile within the next couple of weeks, so we'll see what the trap speed has to say as well. It will be nice to have both dyno numbers as well as 1/4 mile times for a nice baseline reference before I start modding it. I'll definitely keep you guys up to date.
JP_GXP
11-01-2009, 11:09 AM
303 bhp... the Lacrosse has 300 ;)
Pauls325
11-01-2009, 06:27 PM
sounds right to me remember that dynos vary myy stock dyno was 250 and 261 but if i would have gone to the same one as you it could have been lower got to keep in mind heat soak and stuff too what are your plans for mods?
Sittingmongoose
11-01-2009, 07:01 PM
tgose numbers sound about right for a stock car, maybe a little low but not by much. Dont forget every dyno is different.
AlabamaGuy
11-01-2009, 10:09 PM
I made 267/310 with the mods in my sig, without the spacer.
texasGXP08
11-01-2009, 11:13 PM
Also, aren't factory power rating taken at the crank?
Vectus
11-01-2009, 11:49 PM
yes...
Sittingmongoose
11-02-2009, 12:29 PM
alabamaguy, those numbers are pretty high, you must have a strong engine
Garou24
11-04-2009, 07:49 PM
I made 240 hp and 272 tq with the mods in my signature....
