General LSX Automobile Discussion - Motor mounts gone bad? How to tell?
1gt2nv
11-01-2009, 02:17 PM
I think my mounts are shot. Not sure though. How can you tell? My car drives great in town. No issues. When I take it out and go wot from 45mph, the car downshifts and has a flutter sound. Maybe the y pipe? If I stay on it, the car will get better the faster I go. It's just from 45 to 90 that has this issue.
slayerized6
11-01-2009, 03:16 PM
being that you have an a4, have a friend power brake the car in drive and reverse. You should be able to see a difference between the two mounts.
1gt2nv
11-01-2009, 05:59 PM
You mean look at the engine while a friend does this? Check to see how much it moves?
slayerized6
11-01-2009, 06:03 PM
yes. if it moves to far, youll know. you might also want to check the tranny mount
Jeff Smith
11-01-2009, 08:24 PM
Same thing..:Dwhen I acclerated up 40 mph and, there was bad noise. I found out >>>http://i98.photobucket.com/albums/l268/dy21247/DSC01094.jpg
http://i98.photobucket.com/albums/l268/dy21247/DSC01095.jpg
Best way you need lift up your Camaro up appx 2 ft at front. Go undercar and check on trans. mount.
If you have strong arms then do lift up-down and shake on trans mount, if there bad loose. You would know that mount rubber wear out and time to replace new one.
1gt2nv
11-01-2009, 08:36 PM
So anyhthing over 40 you would get a niose? Mine does it around 45. I'll check the tranny mount in the morning. Give myself an extra work out. I'm a body builder! I was going to replace the mounts this winter anyways. Now I'm sure I'll have to. Thanks for the pics and info.
