11Past9
11-01-2009, 11:29 PM
I've seen a decent number of LS1 F-Bodies in solid cosmetic shape and claimed solid mechanical shape. I was wondering if there is anything in particular to look out for or if it was basically a crap shoot when buying one of these? For example, I found a VERY nice 1998 z/28 A4 Vert with 110,000 miles on it. Good condition inside and out, but I worry about things like the transmission, rear end, engine etc. I don't care too much about small stupid things but I don't want to buy a car thinking it's in good running order and then my rear end, transmission or engine shits the bed...
What are the important things to consider? The expensive stuff that breaks and is common with these cars and what are the things that don't usually cause concern as long as the car hasn't been owned by a moron?
Rear end: I know the 10 bolt is a weak point of this car, how do you tell if it's on its way out? What are signs? How much is it to fix when and if it does and how often does it happen? What's the solution and how cost?
Transmission: How strong are the A4's and the M6's... when do they crap out and what mod load can they take? When should one expect to do this or that, repair, rebuild etc and how much will the solution cost?
Engine: I'm under the impression that these things can take a beating and last a long time on basic maintenance... should I even see this as a concern?
I am on a low budget, and don't care too too much about mileage but these cars are getting old and cheaper. I'd like one but can someone school me on buying one?
