My94TransAm
11-02-2009, 07:20 PM
I just changed out the high pressure power steering line due to it leaking. Its a 99TA. I did 't disconnect anything but the belt. I went to start it up and nothing. It turns over, but wont start. I looked for all the obvious things. The only thing I found was a coolant temp sensor right behind the power steering reservoir on the head. I went to connect it back, and it wont go into the hole. It appears to be something missing that goes between the sensor on the head and the GM connector. I'm trying to get pictures, but my computer will not connect with my camera. Any thoughts as what could be causing this?
