Advanced Engineering Tech - Is more that 100% VE possible without FI?
Does NASCAR achieve more than 100% volumetric efficiency under any conditions? Is it possible?
I thought this was a fairly simple question. Without forced induction more than 100% VE is impossible. Isn't it?
Beaflag VonRathburg
11-02-2009, 09:11 PM
From what I have read yes, it is possible and it a lot more prevalent than you would think. Perhaps not all the way through the RPM range, but at certain areas yes. I've seen some people claim achieving this with LS engines.
I know somebody who says NASCAR does it with exhaust scavenging.
I used to race in a drag boat class that had the same rules as NHRA Pro Stock (500 ci N/A). I acheived 127% VE at certain areas in the rpm range. This was back in the early 90s. I'm sure that technology has come so far that it is probably higher today in many racing engines.
The Alchemist
11-03-2009, 09:09 AM
You need to understand that air is a fluid, and when you get to maximum efficieny, which is max torque, the air flowing into the intake manifold doesn't stop moving just because the intake valve closes. So when the valve closes, there is a pressure wave behind the valve that is higher than atmospheric conditions and as soon as the valve opens, you can get a pressurized charge.
techrunner
11-03-2009, 01:56 PM
its all about the flow dynamics, and tuning so that a certain rpm will use the pressure waves to maximize flow into the cyl and exhausst scavenging. great for a race car that sits around the same rpm for a long time, but hard to really use on a street car.
blueflamespl
11-03-2009, 07:53 PM
Here is my dyno chart from my L92 headed 402, This dynosheet was generated on a superflow 902 water-brake dyno and reflects FWHP, we had a precision flow meter installed to measure actual airflow and build the VE chart in HP-tuners.
FormulaZR
11-04-2009, 10:25 AM
I believe Pro Stock engines are 125% VE in their powerband...
The whole powerband or just above a certain speed?
If that is a true statement, then I was doing pretty good with 127% VE, 18 years ago.
So just how does one go about figuring VE?
00pooterSS
11-05-2009, 09:11 PM
Its absolutely possible and happens on lots of vehicles, cant really say for sure on how many but it is common. It comes from velocity of the air actually filling the cylinder more than the cylinder could have filled its self. Once you get that air moving so fast through the engine it wants to keep going, so at some points it actually rams into the cylinder and overfills it giving you over 100% VE.
And yes its from scavenging, that occurs during overlap. That is when both intake and exhaust valves are open at the same time and air is allowed to flow through the intake into the cylinder and out the exhaust, at some point that flow gets moving so well that when the exh valve closes and the intake is still open the air keeps flowing in with velocity behind it and there it is 100+ VE
For instance the cams with lower LSA give you more overlap, and that works both positively and negatively depending on what your goal is and where you use it. At higher RPM it gives you more scavenging but low RPM it gives you an adverse affect and a rough idle. It also plays a role into power band etc etc etc etc... cams are complicated and so it this discussion lol.
Thats my laymans term description after a few beers hope it makes sense :)
I dont know if you can actually figure VE, you can measure it though, but thats getting beyond my understanding of it all.
blueflamespl
11-05-2009, 10:18 PM
The graph I posted on my 402 was with some 1-7/8" American Racing F-body Headers that have a nice merge collector with a "velocity spike". It actually showed a significant gain in the touque output and VE over the 1 -7/8" dyno headers we started with when I dynoed. If I get a chance I should plot them one over the other, it would be interesting. Kurt
SS02G
11-07-2009, 12:12 AM
There are alot of ways to achieve a VE of 100+. For example cam design plays apart by creating vacume using ramp speed and overlap. The intake port itself plays a huge roll buy creating port velocity speeds great enough to force the air keep filling the cylinder even when the air pressure in the cylinder is greater than out side. Another way is Intake runner design using the air's natural want to ossicilate back and forth to create pressure at optimun time when Intake Valve Open occurs to give a supercharging effect. Ferrari Does this alot. So yes a VE of >100% can be achieved not extreamly easily but is possible.
DREAMZ28
11-07-2009, 02:27 AM
Intresting..
What would you figure is the average VE for a stock LS1?
Or to the extreme what is the VE of a TF Dragster? 8khp 500ci
DREAMZ28
11-09-2009, 12:05 AM
:secret2:
00pooterSS
11-09-2009, 02:27 PM
Those motors use forced induction so the VE discussion doesn't apply
FormulaZR
11-09-2009, 05:30 PM
Plus nitromethane.
Coreyc619
11-12-2009, 12:00 AM
there are VE formulas if you google. but those are THEORY.. like based on your displacement your theoretical VE could be... in any specific instance it must be measured.
nitromethane doesnt have anything to do with VE...? sure you can add nearly 9x as much fuel/same volume of air but.. how does that affect VE?
DREAMZ28
11-14-2009, 09:11 PM
I would imagine you could use any fuel and the VE would be virtually the same. VE is basically just measuring how much power the motor is making versus how much it should theoretically be making, IF im not mistaken. Don't blow up if my idea on this is wrong though, I am only 15.. Still waiting on some educated ls1tech'ers to drop by and share knowledge.
1989GTA
11-16-2009, 07:22 PM
"The graph I posted on my 402 was with some 1-7/8" American Racing F-body Headers that have a nice merge collector with a "velocity spike". It actually showed a significant gain in the touque output and VE over the 1 -7/8" dyno headers we started with when I dynoed."
Your test shows how important a well constucted set of headers is and especially the collector area. Also the entry into the header from the head. That is the first time I have seen a dyno chart with the VE posted along with it. Thanks for the interesting post.
