Gears & Axles - Axle bearing for MOSER 9 inch
thechef
11-02-2009, 07:52 PM
help need part number for axle bearing
i need the part number for a axle bearing for my MOSER 9 inch 31 spline axle mine has a o-ring, the ID is 1.53 and the OD os 3.149
can i use a bearing that doesnt have a o ring?
where can i get this bearing locally?
DutchmanZ
11-02-2009, 09:40 PM
here is some irony. try a 2 sec. search
http://www.ls1tech.com/forums/gears-axles/1186577-ford-9-moser-axle-bearing-part-number.html
thechef
11-03-2009, 07:21 AM
thanks, already did that, and NAPA doesnt recognize those numbers, and if you read they/ dont list show the bearing with the o ring in their computers:engarde:
thechef
11-03-2009, 07:31 AM
Thanks Jaw Gears, BCS or Timken Bearing #514003
danhr
11-03-2009, 07:42 AM
all you have to do is go to the parts store and ask for an axle bearing for a early style (66-79) ford bronco.
The o-ring is just an aftermarket solution to try to fight off the typical axle bearing leaks. You can use a bearing without an o-ring, just remember to put a light coat of silicone around the outside of the bearing to help seal it with the housing, so you don't leak gear oil on to your wheels/tires.
