New LS1 Owners - Newbie Tech - borla exhaust question
APG12
11-02-2009, 08:51 PM
I bought my TA with the borla already on it. Ive since read that they are adjustable. What exactly is adjustable on it?
egott_91
11-02-2009, 08:55 PM
Before the right rear exhaust tip, there will be a split in the piping and you can unbolt that and slip in one of the 4 plates, i believe it came with 4, to adjust the sound of it. The bigger the plate=the louder the car and vice-versa. You can also run no plate which would be the loudest.
APG12
11-02-2009, 09:00 PM
ok cool thanks... I only have whatever plate is on there now. Ill have to take a look tomorrow
egott_91
11-02-2009, 09:12 PM
Not a problem man!
Urban Legend
11-02-2009, 09:14 PM
If you have the adjustable one. There are 2 of them. One is adjustable the other one is not.
APG12
11-02-2009, 09:18 PM
Oh ok i thought they were all adjustable. Ill take a peek underneath tomorrow and see what i got.
ShadowCat
11-03-2009, 12:36 AM
You can tell the adjustable from the non adjustable simply by looking at the tail pipe tips. If you have four of them, and they are basically square in shape, you have the adjustable one most likely. If you have only one round one on each side, you most likely have a non adjustable one.
That of course is assuming the tips that came with the setup were put on, and not some other ones... That's a quick way to check without looking under the car, otherwise look for the split in the right side pipe before the muffler.
I have the adjustable Borla and in place of the plates, I have an electric cutout where the pipe splits. That way I can go from full closed to full open, and anywhere in between, with a flip of the switch. No getting under the car and take a plate out and putting in a different one if I want to change the sound...
solo21
11-03-2009, 10:29 AM
I have the same thing and it sounds awesome!!
APG12
11-03-2009, 10:54 AM
I have the two dual square tips so it sounds like its the adjustable one. I like the idea of putting a cutout there. I was thinking about getting one and that sounds like a good place to put it. Although the exhause is pretty loud as is.. im always setting off car alarms :eyes:
FST SS
11-03-2009, 11:10 AM
if it is already pretty loud you probably don't have any baffle in it. I have the Borla and no baffle and it is basically a cut out. It's not real loud until WOT.
APG12
11-03-2009, 11:30 AM
Yea im thinking it doesn't have a baffle in there right now. Haven't had a chance to look yet. Its pretty loud all around not just at WOT but i love the loud deep tone.
ShadowCat
11-03-2009, 12:19 PM
You'll love having the electric cut out there... Sounds great, and if you want to be respectful of neighbors at night, or early morning, you just close it... Convenient, yet allows for full enjoyment of a deep rumble...
