grobb284
11-02-2009, 09:00 PM
Here is the standard LS1 cooling diagram:
http://farm3.static.flickr.com/2724/4069917747_525e10c0f0.jpg
Here is what I am considering doing.
http://farm3.static.flickr.com/2573/4069917773_ef8605aeb9.jpg
1. Eliminate all routing for heater. Not needed at present.
2. Run steam vent into top of water pump. I understand this is a common procedure. (blue line)
3. Tie expansion tank to the low pressure side of the system. This would be on the line exiting the radiator and going to the inlet for the water pump. (red line)
This is where it gets unusual:
4. I read that the Cobra R Mustangs used the overflow line from the standard radiator as a bleed line to an expansion tank by using a special cap.
What if I used a 7 LB. cap here? When the system reached 7 lbs, wouldn't the overflow become open to the expansion tank? Wouldn't it stay open as long as the system continued to run, (ie. over 7 lbs)? (orange line)
5. I would use an 18 LB cap on the expansion reservoir, with an overflow line (green line) going to a reservoir.
I understand common practice is to use the higher pressure cap on the radiator, and the lower pressure cap on the expansion tank. But I am not venting the radiator line to atmosphere, but keeping it within the pressurized system. The advantage is I can use a standard radiator without welding in new bungs.
Will this system work, including the expansion tank tied to the water pump inlet line (red line)??
