Dynamometer Results & Comparisons - can you lock and unlock converter while on dyno
mknight759
11-03-2009, 01:21 AM
my question is can you activate the lockup on the converter while its on the dyno to make a pull then unlock it to make a pull then you could see how much hp you are losing through it i know you would have to have the truck moving to lock it but do they do that or can you do that having my truck dynoed again on wed driveshaft broke the first time just curious i have the feeling that my stall is not working correctly
edcmat-l1
11-03-2009, 06:53 AM
Yes.........
BTW, caps and punctuation makes reading easier.
mknight759
11-03-2009, 08:02 AM
Yes.........
Well yea punctuation would probably be better just never used it unless i was typeing a letter or something important. It would probably be a good idear to use it all the time im not that good at it anyway.
Gh0st
11-03-2009, 08:16 AM
http://img363.imageshack.us/img363/4805/30kcdgpvw2.jpg
Damian
11-03-2009, 09:18 AM
Certain types of tuning software can lock the converter, and a Tech 2 scanner will also lock it.
Gh0st
11-03-2009, 10:36 AM
I believe I've done it in HPtuners once. VCM controls should have a lock option.
mknight759
11-03-2009, 01:13 PM
:flipbird::moon::wave-finghttp://img363.imageshack.us/img363/4805/30kcdgpvw2.jpg
