Generation IV External Engine - l76 map sensor ??
blackbyrd
11-03-2009, 12:32 PM
i ahve the l92/l76 combo on my 414 setup and i had made due with an old map sensor from a ls1 setup and a bracket i fabbed up, but now that teh ecm is giving me map codes without looking further into im probably going to just replace it as im sure its not sealing as well as it should.
so my question is can i just get a ls3 map sensor and plug it up to my ls1 wiring and ecm?? or is there an other option.
thanks in advance
blackbyrd
11-03-2009, 09:35 PM
anyone??
69LT1Bird
11-04-2009, 07:10 AM
The connector is different. Why not just replace it with another LS1 style?
blackbyrd
11-04-2009, 12:42 PM
the l76 one is in a different location and mounts different
the ls1 map clips slash plugs into place and is in the back
the l76 has a tab and a hole for a bolt to go through it and is behind the throttle body.
unless they make a ls1 map that bolts on like the l76.
rojs234
11-04-2009, 01:35 PM
Don't know if this will help. I have included a picture of the map sensor that was in my L76 manifold, (which I have since sold) It was the one you mentioned that fit just back of the throttle body. In case you can't read the part #, it is Delco #16212460. I'm sure it will interchange to a parts store #.
Hope this helps. Ron
blackbyrd
11-04-2009, 01:47 PM
that is the style sensor i have now, but my manifold has a bolt hole to hold it in place instead of the the clip tab like the one you have pictured
69LT1Bird
11-04-2009, 01:48 PM
ACDELCO Part # 12614970 {replaces 213-331 #16212460, 213331}
Category: Manifold Pressure (MAP) Sensor
The 2002 LS1 F car uses the same sensor. 12614970 is the F car part number.
blackbyrd
11-04-2009, 01:49 PM
this like what i would need unless that is a bracket and not the sensor
http://www.lgmotorsports.com/gallery/albums/userpics/10001/LS3%20MAP%20sensor%20close%20up.JPG
69LT1Bird
That means you have a LS3 intake manifold, not a L76.
MAP SENSOR 12591290 213-3842 has provisions for both a bolt and snap in design.http://cgi.ebay.com/ebaymotors/MAP-SENSOR-12591290-213-3842-07-09-COBALT-IMPALA-MALIBU_W0QQitemZ230394923351QQcmdZViewItemQQimsxZ2 0091103?IMSfp=TL0911031810003r28030
blackbyrd
11-04-2009, 01:51 PM
the outside of the intake runners on mine are not rough like the ls3 and i got it nearly 2 years ago was the ls3 even availible then?
69LT1Bird
11-04-2009, 01:55 PM
The acoustic cover and bolt in style MAP are dead give-aways. Model year 2008 was the first year so they were available in 2007 calendar year.
blackbyrd
11-04-2009, 02:03 PM
any other way to idnetify them i dont have the cover , i got it from a member on here when i was building my setup for 175 bucks and was told it was an l76 so thats why have been saying that,
and i missed the link you put to ebay can i use that sensor with the ls1 ecm?
rojs234
11-04-2009, 02:04 PM
I can't say for certain since I don't have the manifold anymore, but I seem to recall that it had an extra bracket that the MAP snapped onto, but I am certain that mine was an L76 and it was new and that is/was the MAP sensor. It is the same as an LS1 and I still have it and use it on my MSD 6010.
blackbyrd
11-04-2009, 08:07 PM
ok so now i just need a for sure answer can i use the ls3 map on my ls1 ecm, i know the connector is different, so next question can i modify my connector to use it? or do i need to fab a bracket that works much better
this all started cause im throwing a map code, and im starting at the obvious
69LT1Bird
11-04-2009, 08:28 PM
Internally they are the same 0-5V system, you will need a new connector to use the LS3 MAP. Go to Rock Auto dot com and you can find the MAP and connector.
blackbyrd
11-04-2009, 09:39 PM
thank you very much
