New LS1 Owners - Newbie Tech - how to ls1 to ls2
View Full Version : how to ls1 to ls2
Zerokube
11-03-2009, 03:50 PM
Wondering if anyone can give me a list of things i need off of a donor ls2 gto to swap into a trans am, both are m6. Anyone? or can someone link a forum post or topic. thanks
Jon@Texas-Speed
11-03-2009, 04:05 PM
Basically you just need a knock sensor relocation harness and a cam position extension harness. You will either need to buy a throttle cable mount if you are going to run the LS2 intake or move your LS1 intake and TB. This of course is if you have a fully built LS2 to put in the car. If you just have a short-block, you will need a new front cover and timing chain w/ the 1x cam signal along with the harnesses listed above. We have everything you need to get the job done. Let me know if you have any other questions!
Thanks!
Jon
Zerokube
11-03-2009, 04:06 PM
intake to oil pan, and full tranny. can the stock ls1 wiring harness work with it?
Jon@Texas-Speed
11-03-2009, 04:18 PM
Yeah the factory LS1 harness will be fine with the addition of the harnesses I mentioned previously.
Jon
