Tools & Fabrication - TPMS tool?
View Full Version : TPMS tool?
waltsfastz
11-03-2009, 07:51 PM
as a shop owner I am at the point Im going to have to look into one of these, We have doged the bullet a few times but really needed it other times as well. Anyone know of a decent one worth the$$$. I have connections to get almost any brand at cost. any suggestions?
livefast1
11-12-2009, 08:07 PM
they taught us in more than enough seminars that all you need is a magnet tray. send the car into reset/learn mode, hold the tray next to the sensor until the horn beeps for each tire.
waltsfastz
11-12-2009, 09:05 PM
Hmmm, Ill try that. Does it work for replacement sensors as well?
livefast1
11-17-2009, 09:39 PM
should work on them all
AKlowriderZ71
11-18-2009, 02:33 PM
The Bartec Wheelrite 400 is what you need for your shop. The NAPA part number for the tool kit is NTH 92-1520. About ~$1300 here in Alaska. Plugs into the OBD port to program new sensors, very easy to learn and use.
waltsfastz
11-18-2009, 03:04 PM
Ill check into it. And Ill try the Magnet Meathod.
thanks a lot fellas
luigiandme
11-18-2009, 04:23 PM
The magnet, i know is for C5 vettes. But on most Gm vehicles with TPMS you can enter the learn mode and starting from LF going clockwise ending at LR, you can release air or add air to the tire and it will honk once recognized. ie. Trailblazer... Key On, Pull parking brake lever, cycle headlights from on to off/auto three times within 3 seconds and horn will honk once done, the bcm is now in tpm relearn mode. Starting with LF, add or remove air for about 5 seconds. Pause and wait for a honk, if no honk, continue to remove or add air to the same tire. Then continue on to the RF then RR then ending in the LR and usually the vehicle will Honk Twice, notifying you that it is Done relearning and is no longer in the relearn mode. Cycle the key once and start the car.
luigiandme
11-18-2009, 04:33 PM
Or buy the J tool... J-46079 Search Ebay for that bad boy!
Mario.
