blackstang3o2
11-03-2009, 08:54 PM
Long story short..Went to change rusty fuel filter with a wix brand filter. Reconnected the lines. Went to cycle the pump and sprayed fuel out everywhere. Pulled quick disconnect line off and the little o rings fell out busted. called the dealer got some replacement right tried again still got a small leak. I cant figure out how these go. So I said screw it I will just order a line assembly so I know its right. Dealer said that item is no longer available.
Has anyone ran into this issue and what did you do to fix it.
thanks
thanks
