Dyno & Bench Racing Forum - What et with this 6.0 mustang
96gtdan
11-03-2009, 09:32 PM
What would this setup in a 1996 Mustang give me et in 1/4. Stock Lq4 bottom end with Texas Speed ported ls6 stage 2.5 cnc'd heads 64cc, Texas Speed Torquer V.3 cam 213/234 643"/598". Fast 92mm intake and throttle body setup. Dynatech 1 3/4-1 7/8 stepped primary tube full headers. Performabuilt level 2 4l60e and 9.5 inch 4600 stall. Car weighs 3460 with me and full tank of fuel. Has adjustable upper and lower control arms, adjustable rear shocks, Competition engineering anti-roll bar. Anthony Jones tubular k-member, A arms, and coilover shocks up front. 8.8 with 3.73s. Mickey Thompson 26x11.5 et streets. Hp tuners tuning by me and friend.
78novacaine
11-03-2009, 10:26 PM
i would say about the same as i would give an f-body with similar mods, mid-low 11's if you can hook it up, which it sounds like you will have that taken care of
96gtdan
11-04-2009, 07:16 AM
Thanx So that will get me well n the 10s with 100 shot if decide to add the nitrous.
Juicy J
11-04-2009, 10:27 AM
There would be a problem with your car if it didn't run 10's with a 100 shot.
78novacaine
11-04-2009, 10:51 AM
:werd: and if you get it setup right it jsut may crack a 10.9x on motor, but i wouldn't get your hopes up
96gtdan
11-04-2009, 01:36 PM
I ran 11.60s with 1.60 60fts with stock 4.6 pi head swap motor with uper plenum and throttle body and full headers and exhuast with 140000 miles on the motor and 150 shot with 5spd. I was hoping 11.20s on motor b great time for bracket class i run. Friday night play nights b 4 the nitrous. Thanx again all think on the right track then with my combo
silverz28camaro
11-04-2009, 01:39 PM
Is the car done? post up some times when you run it.
180ls1
11-04-2009, 01:56 PM
that car should be in the low 11's maybe 10's with some really good air and some weight pulled out.
96gtdan
11-04-2009, 05:30 PM
No the car is not done just getting started. Have the rear suspension done in process of changing kmember A arms and coilover conversion. Have the new level 2 tranny and converter on the way. Will b mid summer b4 times will b posted have wedding 2 pay for and baby on way lol. There is videos on utube of the car with the 4.6 under Srca fan. Or just search for wichita drags 2.
96gtdan
11-10-2009, 09:35 PM
:eek2::owned::owned::owned:
