Gears & Axles - Need some help with swipe pattern
View Full Version : Need some help with swipe pattern
nvmy2000ss
11-03-2009, 11:43 PM
I know this is a repetitive question here but I just want to make sure. My instinct is telling me to put another shim on the pinion to move the pattern to the foot of the tooth but I just wanted to get some opinions.
Coast
http://i8.photobucket.com/albums/a24/nvmy2000ss/DSC00713.jpg
http://i8.photobucket.com/albums/a24/nvmy2000ss/DSC00712.jpg
Drive
http://i8.photobucket.com/albums/a24/nvmy2000ss/DSC00715.jpg
http://i8.photobucket.com/albums/a24/nvmy2000ss/DSC00714.jpg
Scott@DrivelineSolutions
11-04-2009, 09:48 AM
What is the pinion shim, backlash, and who's gear is it?
nvmy2000ss
11-04-2009, 10:30 AM
pinion shim is at .032 backlash is set at .009 these are richmond 3.73 gears.
Thanks
11-04-2009, 11:46 AM
Ok, drop the pinion shim to .030 possibly a .028, the drive looks deep, and keep the backlash at .009.
nvmy2000ss
11-08-2009, 10:29 PM
coast
http://i8.photobucket.com/albums/a24/nvmy2000ss/DSC00736.jpg
drive
http://i8.photobucket.com/albums/a24/nvmy2000ss/DSC00735.jpg
http://i8.photobucket.com/albums/a24/nvmy2000ss/DSC00734.jpg
11-09-2009, 09:55 AM
The drive got worse, you did not post up a coast pattern. Try to move it to .034. shim if the coast moved towards to OD of the gear.
KurtRardin
11-09-2009, 10:06 PM
As long as you post up pics of the final gear pattern and keep listing what shims you're using in the pics then this will make for an excellent cause-and-effect thread. Thanks!
:smokin2:
01ssreda4
11-14-2009, 11:44 AM
:smokin2:
Ha good point :D
