Fueling & Injection - driver box for high hp and e85.
z28adiction
11-04-2009, 02:49 AM
i was just curiouse if it would be possible to run a driver box to run (120-160lb) injectors with e85 to make around 1000 hp in a twin turbo car. i know stand alone would be the best way... but i was jw if this would be not only possible but safe and reliable as well thanks.
FICINJECTORS
11-04-2009, 07:43 AM
i was just curiouse if it would be possible to run a driver box to run (120-160lb) injectors with e85 to make around 1000 hp in a twin turbo car. i know stand alone would be the best way... but i was jw if this would be not only possible but safe and reliable as well thanks.check this out.. You can use stock computer and no driver box
http://www.ls1tech.com/forums/fueling-injection/1200578-150lb-bosch-high-imp-injector.html
Big_Bird_WS6
11-04-2009, 11:44 AM
this is what i plan to do make 1000 on e85
Nasty N8
11-04-2009, 02:02 PM
$150 per inj. I can do a driver box and 8 inj for $799 and works very good for high HP cars they idle very well too.
Nate
