Gears & Axles - Moser 9" ABS problem..... EPP can you HELP?
LS1HIGHLIFE
11-04-2009, 08:04 AM
Everything is hooked up all good and no loose connections or bad fuses however, I've had my ABS light on for a while now.
ref: http://www.ls1tech.com/forums/suspension-brakes/1200609-new-rear-dif-gears.html
Every time I press the brake pedal I get the ABS module pulsating trying to work but it just doesn't. Is there anything I can do to check the 9" rear sensor to make sure it's reading the reluctor ring correctly?
Exotic Performance Plus
11-05-2009, 06:03 AM
Try pulling the sensor out of the rear and clean the break in shavings/debris off of it. This may be all you have to do. Bob
LS1HIGHLIFE
11-05-2009, 06:24 AM
Thanks Bob I will try that when I get back into town.
11-07-2009, 05:27 AM
You're welcome, let me know if it takes care of it. Bob
LS1HIGHLIFE
11-17-2009, 06:18 AM
Well cleaning off the sensor helped with the pulsating of the ABS every time I pressed the pedal but my light will not go off.
Do I need to reset my ECM?
11-18-2009, 04:45 AM
I'd disconnect and reconnect the battery and see if it goes away. Bob
