RPOWU8
11-04-2009, 12:28 PM
For Sale: FLT 4L60E Level 7 transmission.
•300M billet input and output shafts
•FLT machined performance pump
•Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
•FLT sleeved input drum w/ FLT billet aluminum overrun piston
•FLT beast shell kit w/bearing kit
•GM 5 pinion input carrier
•GM 5 pinion reaction carrier
•Bearing style reaction shaft
•New reverse input drum
•Alto wide 2-4 carbon lined band with reinforced anchor
•8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
•B/W 29 element sprag
•4L65 low roller clutch
•Transgo HD-2 shift kit
•Corvette Servo
•Sonnax super hold 4th servo
•Bushing kit
•New solenoids
•New Internal wire harness ( If needed on 4L70E )
•New GM Spacer plate
•B/W clutches
•Seal & gasket kit
•Filter
•GM deep pan
•Updated aluminum accumulator pistons
•FLT prepped valve body w/ HD shift valve
•Set end play to FLT specs
•Case cooler fittings
This was built to be my spare and I just had built last month. I'm now building a new short block for the car and need the money for parts.
I'm looking to sell in the So Cal area.
$3000 Firm
•Corvette Servo
•Bushing kit
•New solenoids
•B/W clutches
•Seal & gasket kit
•Filter
•GM deep pan
$3000 Firm
