Racer's Lounge - Poll: What LS combo (affordable) would everyone want to see built?
ATK
11-04-2009, 02:03 PM
Just like the title says...and be realistic on what you would spend. Carb?, EFI?, turbo?, blower?, nitrous?
Thinking of building a base 408 as a starting point, maybe using the best of what the General has (LS2 heads for example...the usual offerings) and mix matching to get a decent engine while stuffing it with Scat internals (at least the bottom end will be bulletproof) and a killer camshaft
Your thoughts please!
What was the line in Field of Dreams? Oh yeah...
"If you build it...they will come"
ThumperNC24
11-04-2009, 02:17 PM
I would love to see a really high revving (8000+) twin turbo motor.
Perhaps a 5.3L. Smaller Turbos for really quick spooling and then a decent amount of power.....
streetassasin
11-04-2009, 02:23 PM
affordable? Forged 347, ported gm castings, nice cam, victor jr, accufab 4150 and a direct port
ATK
11-04-2009, 03:02 PM
Both good points/ideas
I was under the impression the average joe would want a stroker kit tho:thinker::confused:
*btw...I have access to an iron LS2 block to have my way with:devil:
-Ross-
11-04-2009, 03:15 PM
Cammed LS3 with a Magnacharger. Simple, reliable, good power.
supernova1972
11-04-2009, 03:33 PM
Generally 5.3s are most affordable. Im putting a H/C 5.3 in my c10 for next summer, then doing a small twin turbo custom kit for it after I do the frame of next winter.
smokinponcho73
11-04-2009, 06:47 PM
a 408 with a nasty cam and some TF235's on a 250-300 shot well atleast that's what my plans are.
406malibu
11-04-2009, 07:01 PM
You mean an LQ4/9... never made a iron LS2.
NemeSS
i alredy built my affordable ls engine. and has around 40k miles on it now.
490rw with cast pistons, stock rods,crank,
and upgraded unported oe heads,ls6 intake
:corn:
allbaugh_04
11-04-2009, 07:21 PM
LQ4/9...spray it. See how much it can handle :devil:
djsanchez2
11-04-2009, 09:21 PM
LQ iron block (.030 over for 370ci)
Compstar rods
Eagle pistons
Stock crank
L92 heads
Ported Vic Jr.
1100cfm Dominator
PatG or PredZ spec'd cam
N20 (250+shot)
djsanchez2
11-08-2009, 07:02 PM
ttt... i wanna see what this guy decides :D
Detoxx03
11-08-2009, 07:26 PM
I would also like to see a LS3 with a Maggie and a nice cam.
chadaclysm
11-08-2009, 07:30 PM
I want to see some big cubic inches with so much cam it sounds like it is going to die.
shawn_c992001
11-08-2009, 07:57 PM
LS3 with some cubes, forged bottom, great flowing heads, awesome turbo cam, and compound turbos, giant intercooler, progressive meth and some N2O through the turbos!!!
djsanchez2
11-08-2009, 08:06 PM
^^^^ :lol: that does not sound budget friendly at all
teke184
11-09-2009, 08:09 AM
i realize its not exactly what you're asking for....but
i'd love to see a head comparison on a decent sized stroker.
build the 408 with a pretty healthy cam and say...stock 243s for heads.
then swap out and dyno each set of heads:
AFR 205s
AFR 225s
TFS 215s
TFS 235s
ported 243s
keep everything else the same...except the tune of course.
see how each head affects low/mid range power, peak power and things like that.
its a comparison i've never seen on a stoker
shawn_c992001
11-09-2009, 11:31 AM
When I win the lottery it will be in my budget!!!! LOL
